How to fix a floating idle on a Toyota 4A-GE motor
06-30-2013, 01:07 PM
Finally, yesterday I fixed it, with a little help from my metalworking skills and simple tools!
In this video I showed how I adapted the throttle position sensor from another 4A-GE bluetop, that had a different prong layout (vertical instead of horizontal). I had to craft a part that fitted in the throttle body, to activate the "new" throttle position sensor from a vertical position instead of the horizontal one used by my old TPS. I tried fixing the vertical one to the horizontal plate without machining the new part... the only result was that there was not enough twisting margin left in the sensor, causing the throttle to be stuck like 5mm after pressing the pedal, which made the engine go much slower. Due to the lack of opening in the throttle, the PWR light on the dash never came on (it stayed always in the ECON mode). Enjoy, and tell me if this helped you!
E12 2.0 D-4D - 2002 - "Mariazinha" - ![]() G6R - 1998 - "Bebedolas" - ![]() AE86 - 1987 - "Charutinho" - ![]() Check out my Youtube Channel with lots of AE86 DIY Guides! |
| Messages In This Thread |
How to fix a floating idle on a Toyota 4A-GE motor - Homem Bomba - 06-30-2013, 01:04 PM
[] - Homem Bomba - 06-30-2013, 01:06 PM
[] - Homem Bomba - 06-30-2013 01:07 PM
[] - Homem Bomba - 08-24-2013, 12:46 PM
| No idle below 2000 rpm rich running | Steller Engineering | 3 | 2,858 |
| Engine starts/revs but no idle | GenkiMotors | 17 | 11,673 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
| exhaust odor/idle MOT issue | Ryo | 7 | 9,754 |
| 20v silvertop idle issue | AlexFourTwenty | 3 | 6,552 |
12-24-2017 03:27 AM Last Post: AlexFourTwenty |
| Silver top low idle | AlexFourTwenty | 7 | 12,488 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
![AEU86 AE86 - [Image: AEU86 AE86 - ]](https://images.spritmonitor.de/462732.png)
![AEU86 AE86 - [Image: AEU86 AE86 - ]](https://images.spritmonitor.de/546718.png)
![AEU86 AE86 - [Image: AEU86 AE86 - ]](https://images.spritmonitor.de/465770.png)
