How much performance gain from headers ??
11-04-2008, 09:56 PM
forgot to mention: my engine is with MAP, no cat, no O2 sensor.
SFD |
11-04-2008, 10:06 PM
buy the trd engine mounts and u will skipp the clearence problem
![]() Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
11-04-2008, 10:08 PM
11-04-2008, 10:42 PM
I was planning on getting lowering mounts at some point. Didn't know the trd ones were also lowering. But would it be enough? They shouldn't be lowering the engine for more than 1cm, right? That would only give me the clearance required if the header fitted was just touching the floor...
SFD |
11-05-2008, 01:46 AM
Depending on how much tube length you have to play with, and how
many tubes you have to bend, it may be possible to do it by heating. Basically, the technique involves heating up a spot with a gas torch until it is dull red, and then quenching it with water. The tube will bend (shrink) a little at that spot. By repeating the process several times on the same side of the tube, the tube will begin to bend in that direction. Obviously, the further away you can make the bend from the spot that is touching, the easier it will be to gain clearance. The heat will spoil your bling header pipe, but after a while the whole pipe will go brown anyway ![]() Cheers... jondee86 |
11-05-2008, 01:50 AM
drako323 Wrote:forgot to mention: my engine is with MAP, no cat, no O2 sensor.No O2 sensor = not good emissions and not good economy. Cheers... jondee86 |
11-05-2008, 11:54 AM
Most European hachis didn't come with catalytic converter, so most of them don't have the lambda and/or oxygen sensor either.
1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
02-21-2009, 01:14 AM
How much performance gain from headers ?? | |||
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 23,660 |
Headers recognition | FanIsHere | 2 | 3,926 |
11-23-2020 02:28 PM Last Post: FanIsHere |
LHD AE86 headers and exhaust | Lt86 | 54 | 74,682 |
05-25-2017 06:13 PM Last Post: zenki |
weir performance email | filh | 2 | 5,517 |
06-14-2015 05:37 PM Last Post: oldeskewltoy |
Weir Performance rear upgrade kit for AE86 | heshan | 5 | 10,242 |
07-22-2013 09:11 PM Last Post: heshan |
