Help with Kouki Trueno bumper cover install!!!
11-16-2007, 04:12 AM
I am in need of some help with the installation of a kouki trueno bumper cover on my 1985 sr5 corolla usdm. I have the brackets on order to install. I know I need them, but I can't seem to place how to mount the bumper correctly. Do I need to remove the factory steel bumper? If you could point me in the right direction I would be very grateful. I also tried to fit the bumper and and it would not fit around the factory sr5 bumper because the actual bumper is too thick in reference to the area to bolt up the trueno bumper cover. Any help would be much appreciated. Maybe a write up or link!?
I can add photos if someone is better visually looking at the problem.
11-16-2007, 04:52 AM
//wannabe mod mode:
I'm no bumper expert, but i'm fairly good with computers. PrOpEr use of capslock or shift can make your posts look a bit more friendly and modest
foto's would be handy Big Grin
He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which.
11-16-2007, 07:26 AM
You need to remove the complete USDM bumper... at the frame. The new brackets will have 4 pick up points. Once the brakets are on... and you slip on the cover, I'm sure mounting points will be revealed.
Are you also getting kouki turn/parking and cornering lamps??? If you have USDM bumper and you want to wire in the lights to operate correctly... then you need to do a bit of wiring
[Image: AEU86 AE86 - Help with Kouki Trueno bump...install!!!]
Dan -
11-16-2007, 10:42 AM
senna Wrote://wannabe mod mode:
Thanks Thumbs up!
Just corrected the title. Wink
  Kouki door card removal - help :) ondafly 2 534 03-08-2026 11:51 AM
Last Post: ondafly
  Bash bar for zenki trueno bumper gh0st 3 3,778 02-08-2023 10:50 PM
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 13,960 12-19-2021 11:58 PM
Last Post: gh0st
  Trueno headlight help kazi 9 16,614 04-20-2017 09:37 AM
Last Post: kazi
  JDM trueno not starting. need help! kazi 8 11,813 03-12-2017 05:05 PM
Last Post: kazi
