Help needed for Starlet KP61/62 4AGE conversion
09-27-2005, 08:42 AM
I was thinking of buying a starlet as a winterbeater this coming winter. And I thought to myself, i have a 4AGE lying in the shed, including the AE86 wiring loom and an extra ECU....hell, i´ll make me a fun wintercar, and then when winter is over, make it a drift/track car.
But....
Are any of the KP models better suited for this conversion, and what about the gearbox fitment, will the OEM box fit, or will i need a T50 gearbox for it?
Any help and input would be much appreciated.
My evil Red/Black Panda
My current JDM AE86 project
09-27-2005, 09:17 AM
In australia en the usa are some "ap60" built.
i think the normal k40/k50 gearbox wouldn't mount on the 4age block.
And can't hold the power.
Check this forum:
toymods forum
mark
09-27-2005, 09:20 AM
I think there's a kp61 forum somewhere out there....that might be worth a shot..otherwise there is at least 1 guy on club4ag that has a 4ag KP61 who you could try to email. He uses the car for auto-x and kept getting bumped up to higher classes because the porsche owners couldnt deal with the fact that they where getting their arses whooped by a granny starlet.
09-27-2005, 09:39 AM
I think i saw a 4AGE powered KP61 somewhere inhere: http://www.kp61.net
09-27-2005, 10:41 AM
IMHO peter, if you go to 4AGE powered KP Starlet - the best way is to use engine, gears and rear end from AE86.
09-27-2005, 10:43 AM
you need to fit a hydraulic clutch (and everything needed to make it work of course Wink), because a K40/K50 gearbox has a cable clutch and won't bolt up to a 4A-GE, also don't know if it can hold up the power.
Also a T50 is longer then a K40/K50, so you need to shorten the driveshaft. And need to cut a hole in the tunnel, because the lever is a bit more backwards.
On my KE20 i can use a Carina TA12/TA14 2T driveshaft, dunno about the KP60.
  20v Blacktop conversion.... Mylesmck 0 2,046 04-29-2024 05:48 PM
Last Post: Mylesmck
  Kouki to Zenki Levin grill conversion? Mylesmck 6 6,593 02-08-2024 10:30 AM
Last Post: r.ave
  AFM to Map Conversion ps13michi 3 6,584 01-06-2022 10:34 AM
Last Post: ps13michi
  Sub panel and rotary-button replacement for Levin -> Trueno conversion gh0st 9 11,212 11-05-2021 08:17 PM
Last Post: gh0st
  Help needed totta Crolla 3 6,148 05-15-2020 10:07 AM
Last Post: totta Crolla
