Help me AEU86, you're my only hope
03-22-2021, 02:25 AM
If you have the car idling in the optimal range and you pull the hose off the MAP sensor
the gauge should move until it is showing rich. That's about all you need to do to check if the MAP sensor is working. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
03-22-2021, 10:16 AM
Probably worth checking that your O2 sensor is telling you the truth. It should be showing somewhere between 0 - 1v on your meter. To give a stable output an un-heated sensor relies on high exhaust temperatures and this is typically achieved when the engine is under load. I use a narrowband sensor to feed back to my ecu and a wideband to tune. With both sensors fitted it became obvious that the un-heated narrowband sensor was sending rubbish until it got really hot. Fitting a heated sensor cured this.
03-24-2021, 12:21 AM
(This post was last modified: 03-24-2021 12:27 AM by Nakilad.)
(03-22-2021 02:25 AM)jondee86 Wrote: If you have the car idling in the optimal range and you pull the hose off the MAP sensor I tried this, and all it really does is idle like a sack of s**t. nothing really changes on the gauge. You can see / hear this in the 4th video of the playlist. (03-22-2021 10:16 AM)totta Crolla Wrote: Probably worth checking that your O2 sensor is telling you the truth. It should be showing somewhere between 0 - 1v on your meter. To give a stable output an un-heated sensor relies on high exhaust temperatures and this is typically achieved when the engine is under load. I use a narrowband sensor to feed back to my ecu and a wideband to tune. With both sensors fitted it became obvious that the un-heated narrowband sensor was sending rubbish until it got really hot. Fitting a heated sensor cured this. So the voltage is normally at .14 volts. Changing the mixture screw has no effect, but you can hear the change in the idle so it is doing something. If I block off the cam breather hose for 30-45 seconds, and then release it, the voltage will shoot up to around .45 (max) and the slowly settle back down to 0.14 again. I understand what you are getting at here regarding the heat, and it does make sense. I don't think this is the issue but I guess I need to spend another 200-300€ on a wide band sensor and gauge to test this further. As I said earlier, I can't really take it for a long drive without running the risk of getting into a lot of trouble! That said, there is an auto bahn around 3 minutes away so perhaps I should just chance it one evening. |
03-24-2021, 01:06 AM
I don't think it is necessary to sink money into a wideband system, all you really need is a narrowband sensor with a heater circuit. The heater circuit will work on a 12v feed. You can check the real output of your current sensor on a road test. Most non-heated sensor fed ecu's run in open loop at idle because the sensor output cannot be relied upon.
03-24-2021, 01:15 AM
(03-24-2021 01:06 AM)totta Crolla Wrote: I don't think it is necessary to sink money into a wideband system, all you really need is a narrowband sensor with a heater circuit. The heater circuit will work on a 12v feed. You can check the real output of your current sensor on a road test. Most non-heated sensor fed ecu's run in open loop at idle because the sensor output cannot be relied upon. Ok, good idea, i'll look for that first. The sensor I am using is a Delphi ES10226-12B1 (Lambdasensor). Is it possible that the output of this sensor does not match the input required for the Prosport Racing Premium Serie gauge I have? |
03-24-2021, 10:27 AM
"The sensor I am using is a Delphi ES10226-12B1 (Lambdasensor). Is it possible that the output of this sensor does not match the input required for the Prosport Racing Premium Serie gauge I have?"
Apart from a few car manufacturer specifics narrowband sensor outputs are pretty much generic, the changes are in the wiring and the plug connections. The wiring differences are related to the heater circuit (4 wire sensor normally) By all means check with the gauge manufacturer, all you need to know is the input voltage range required. lf it is 0-1v and it almost certainly will be, you are good to go. I am still using a sensor l got from a scrapped car! An analogue brain in a digital World |
03-25-2021, 09:11 AM
(This post was last modified: 03-25-2021 09:36 AM by jondee86.)
(03-24-2021 01:06 AM)totta Crolla Wrote: I don't think it is necessary to sink money into a wideband system... With all due respect, I would suggest that a WBO2 gauge and sensor would be a good investment both for tuning and trouble shooting. A narrow band sensor is fine for a stock engine with an OEM ECU that is set up to work with a narrow band sensor. The "switch-like" output of the sensor hovers around 0.5V. When it is above 0.5 the ECU reduces fuel and when it is below 0.5 the ECU adds fuel. The sensor reacts to the change in fueling so that the up-down-up-down cycle repeats over and over. I believe this can happen several times a second. The problem with the narrow band sensor is that it can not tell you HOW rich or HOW lean the mixture is. Enter the wide band sensor that has a more gradual change in output so that it can be scaled to read from very rich to very lean. When used in conjunction with a compatible WBO2 controller and gauge, you can see on the gauge if you are at 17:1 or 12:1 and how the reading changes with load and rpm. Most WBO2 controllers can output a simulated narrow band signal for feeding to a factory ECU designed to work with a narrow band input. But your gauge will be telling you the actual AFR under all operating conditions. Down the track if you upgrade to an aftermarket ECU the wide band signal can be fed directly to the ECU for automatic or semi-automatic tuning of the fuel map. Incidentally, narrow band sensors are installed close to the head for maximum heating while wide band sensors usually get installed a bit further downstream in the collector to avoid overheating. Cheers... jondee86 PS: And while I've got you here, I'd suggest that you forget about trying to make the narrow band happy and start working on possible mechanical issues. For example... is the TVIS system working correctly ? If the TVIS plates stay closed (don't open around 4200rpm) you will have good low rpm operation but be short of breath at high rpm. Pulling the hose off the MAP sensor should cause a rough idle... maybe need you to play with the throttle to keep it running, and blow a bit of black smoke/smell gasoline in the exhaust. The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
03-25-2021, 10:23 AM
(This post was last modified: 03-25-2021 10:34 AM by totta Crolla.)
The reason a NB sensor hovers around a given voltage is because it is feeding its value back to the ecu, the ecu then changes the fueling to keep the given voltage hovering around a given value. When a NB sensor is used just to monitor it is capable of showing rich / lean values in excess of what is required to run a normally aspirated engine. Here is a video proving such: https://m.youtube.com/watch?v=o6y0OgSnbhk The DTM unit is monitoring using a generic NB sensor. The Innovate LM2 uses a wideband sensor.
lf the problem appears to be that the engine is running lean and that conclusion comes from an instrument reading then surely that instrument reading needs to be correct? An analogue brain in a digital World |
03-25-2021, 11:43 PM
Interesting !! I have seen narrow band gauges that light LED's to show the
voltage, but never one that was actually calibrated to specific lambda values. So that is my new thing for today learned already Claims about reaction speed and legibility are not really helpful. It is difficult to get much information from a gauge that rapidly changing values to track volatile events such as combustion cycles. I used an old Innovate LC-1 wide band digital gauge and it had three settings to slow the gauge down by averaging the displayed readings over (from memory) the last 3, 6 or 12 samples. This cut down jitter on my log files so that I got more realistic "steady state" readings for tuning my fuel map. But I was still able to see what was happening during transitions for adjusting enrichments. The LC-1 controlled the sensor heating and would not allow AFR readings to display until the sensor was at operating temperature. It also had a simulated narrow band output that I used with a factory ECU before I installed a new aftermarket ECU. Then I connected the wide band date output directly to the ECU for maximum accuracy. For an inexpensive gauge and controller package I thought the LC-1 worked very well. However, that is just me and I don't suggest that it is the best or only way to monitor AFR's. You and others may find the combination of wide and narrow band gauges helpful and I have no argument with that. But for the OP trying to troubleshoot with a narrow band that may or may not be wired or operating correctly, I stand by my recommendation. A basic wide band gauge and controller setup, once correctly installed and calibrated in fresh air is going to immediately provide useful information. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
03-26-2021, 01:58 AM
(This post was last modified: 03-26-2021 02:01 AM by Nakilad.)
(03-25-2021 09:11 AM)jondee86 Wrote:(03-24-2021 01:06 AM)totta Crolla Wrote: I don't think it is necessary to sink money into a wideband system... I'll try to cover a few of these points. Its an early model map sensor so there's no feedback from the 02 sensor to the ecu. No modifications have been made to the motor (aside from a rebuild) and its the stock ECU. At the moment all I get out of the NB Sensor at idle is 0.14 volts, clearly to low. The sensor is mounted in the exhaust manifold (I think you can see this in one of the videos). I've got a heated NB sensor on the way (4 wire, so I know it will have a good earth), it should be here tomorrow or Saturday so i'll plug that in and see what happens. I guess if that also doesn't show anything then WB might be the next step! I have two tvis's, been swapped over a few times, seems to make little / no difference. I can say that they are definitely closed at idle (which is the thing I have to work out first before worrying about whats going on above 4500 rpm). I'm not going to take any offence from any suggestions! (03-24-2021 10:27 AM)totta Crolla Wrote: "The sensor I am using is a Delphi ES10226-12B1 (Lambdasensor). Is it possible that the output of this sensor does not match the input required for the Prosport Racing Premium Serie gauge I have?" Yeah, I thought that would be the case. Its a standard prosport gauge to it ranges from 0 to 1 volts as input. |
| Headlights - only high beam working | Jezza_hr | 3 | 9,343 |
01-10-2015 11:59 AM Last Post: jondee86 |
| Whining noise only in 4th & 5th. | izanagi | 7 | 13,918 |
09-25-2014 07:09 PM Last Post: Uzelac |
| 4age 16v 1st and 2nd generation cams and not only difference | Apsogos | 3 | 9,058 |
09-16-2013 08:24 AM Last Post: Apsogos |
| Exhaust Header 4AGE Mr2 Only | Alex170984 | 1 | 4,746 |
02-07-2013 01:36 PM Last Post: Alex170984 |
| hope not a probelm to post here too | sergiocharged | 7 | 8,503 |
06-08-2008 08:52 PM Last Post: banpei |
Claims about
