Hello - Newbie intro ...
08-23-2005, 02:21 PM
Hello
![]() Just registered on the forum and wanted to say ![]() I have been dying to own a AE86 for years now but have never got around to buying one for one reason or another. ![]() My personal circumstances have now changed and I am selling my current car and I am on the hunt for a AE86 which I can use for track days and drifting. ![]() The annoying thing is, I am seeing lots of great Levins and Trueno's which I would love to buy but as my current car still hasnt sold I am being forced to window shop .... which for me is a very cruel punishment ![]() I am so sold on the 86 I am selling my very heavily modified Mr2 turbo for one. Pretty big step especially seeing as I have just invested a substantial amount on the Mr2's engine. ![]() Ah well ![]() Just have to hope the 86 (if I ever finally get one) will live up to my expectations - I am sure it will ![]() Just on the off chance if there is anyone reading this which feels sorry for me and wants to buy my old car off me just let me know! lol ![]() Cheers James ![]() |
08-23-2005, 02:27 PM
Welcome!
![]() I'm ready to swap my red shell for the MR2! ![]() ![]() ![]() |
08-23-2005, 02:31 PM
Welcome!
![]() Did you own a aw11 or sw20? ![]() (and pics from any heavily modded toyota are always welcome ) 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
08-23-2005, 02:43 PM
Hi guys
![]() Quote:I'm ready to swap my red shell for the MR2 lol thats probably the best offer I have had on it so far ![]() ![]() Quote:Did you own a aw11 or sw20? Its an SW20 ![]() ![]() ![]() Plus the Hachi is going to be more fun and more suitable for track days especially on my salary. Quote:and pics from any heavily modded toyota are always welcome Well here is a picture of the car - stock on the outside but a wolf in sheeps clothing ![]() http://www.brown-cow.co.uk/frontquarterviewMR2.gif Here is the spec. Interior - Trust GREX gear knob - Autometer A pillar gauge mount - Autometer boost gauge - Autometer AFR gauge - Autometer Nitrous pressure gauge - Custom pod mount behind steering wheel which houses the boost gauge - Autometer 5 inch race tach - Autometer shift light - Custom stainless steel dash mount bracket for the race tach - ULTRA turbo timer - Double din Fujitsu Ten CD/Tape/Radio player - Kenwood speakers - 180mph dials Exterior - Racing Dynamics silver multi spoke alloys. Staggered set up for better turn in - Eagle F1's (rear), Falken 451 (fronts) good tread all round Engine - Engine has been totally stripped and cleaned through - Engine block repainted bright red - Sump pan repainted bright red - Inlet manifold repainted silver - Repainted rocker cover in crackle finish red - New engine seals, every internal and external engine seal have been replaced - New oil pump - New timing belt - Rebored and honed cylinders - Arias 87mm forged pistons - Ceramic coated piston crowns - Dry lube on the piston skirts for lower frictional losses and better oil dispersion - New wrist pins and locking rings - Eagle H Beam lightweight forged con rods - ACL Duraglide con rod and main engine bearings - SPF (South Florida Performance) stainless steel tubular exhaust manifold - Precision Turbo SC61 (680 rwBHP capable turbo, good spool characteristics) - Goodridge braided oil supply line with Goodridge adaptors and fittings - Russell braided oil drain line with Russell adaptors and fittings - Stainless steel custom turbo downpipe - External waste gate dump pipe is fed back into the exhaust to reduce noise levels - The downpipe and wastegate dump pipe lagged in heat wrap to retain heat - HKS 45mm external wastegate - Toyota metal head gasket - HKS 264 high lift exhaust cam - HKS 272 high lift intake cam - ATS Racing Cam Gears - The cylinder head has been fully stripped and cleaned thoroughly - New valve seals - The valve clearances have also been re-shimmed to factory tolerances - Freshly lapped in valves - The valves have also been thoroughly cleaned and polished - Engle uprated valve springs - Ported and polished head - Fine port polish on the exhaust to reduce pumping losses - Swirl port finish on the intake to promote better mixing of fuel and air - Apexi Power FC and commander (unit currently not fitted and un mapped) - Sard 850cc injectors (as yet not fitted) - ARP rod bolts - ARP main bolts - ARP head bolts - Custom stainless steel induction system - HKS SS BOV - BLITZ Nur SPEC R exhaust system - ULTRA Ignition Leads - Mark Summers Copper Contact Distributor Cap - NGK BCR8ES cold plugs - Crankcase breathers x2 - Walbro 255lph intank fuel pump - Gearbox is totally sound, no crunches on gear changes and is totally solid - Gearbox filled with Redline MT40 as well - Desrestricted - FCD Chassis - Bilstein Sport "yellows" suspension - GAB sport lowering and stiffening springs - GAB front upper brace - GAB front lower brace - GAB rear upper brace - Whiteline front adjustable ARB - Whiteline Rear adjustable ARB - Whiteline ARB bushes (front / Rear) - Sbits drop links - TRD reinforced front engine mount - Custom solid rear engine mount Braking - EBC Grooved and Drilled Disc's - Pagid fast road pads - Reconditioned front calipers - Reconditioned rear calipers - Goodridge Braided Brake Lines Drivetrain - HELIX 4 paddle stage 2 competition clutch - light pedal and tractable in traffic - Custom fabricated short shifter Cheers James ![]() |
08-23-2005, 02:44 PM
Very nice!
08-23-2005, 02:51 PM
you should be able to sell that sw20 for over 7500 euro's than you can buy a pretty big ass ae86
08-23-2005, 03:02 PM
Hello
![]() Looking for about £8.5k - but happy to negotiate on price. ![]() ![]() Probably going to import my own Hachi from Japan, seen a few really nice ones going for around 3k plus and extra 1k to get it to the UK and for me to convert it for the UK. ![]() Just so desperate to buy a Hachi its killing me! ![]() Cheers James ![]() |
09-13-2005, 08:20 PM
i know the feeling james. i just got a hachi myself and trying to sell my old car now.
reasons not to get hachi, its old so it rattles alot, u would be a better babe magnet in ur mr2, ur wife to be might scream her lungs out when she sees the hachi ![]() other than that u have all the reasons to get a hachi. ![]() |
09-13-2005, 09:06 PM
What kind of bhp is that MR producing? My brothers looks very simlar and produces 480bhp.
09-14-2005, 10:27 AM
b1gb3n Wrote:reasons not to get hachi, its old so it rattles alot, Hmm... mine doesnt rattle atall... Perhaps mine is broke? ![]() Youtube Myspace and I´ll Google your Yahoo |
Newbie | 20valver | 7 | 4,146 |
04-20-2024 01:14 PM Last Post: Power_uP |
Newbie | DMC | 4 | 2,218 |
02-29-2024 05:11 PM Last Post: livelaughlevin |
Intro/my ke70 | matthijs | 19 | 17,819 |
12-21-2019 03:38 AM Last Post: DarkSupra |
Newbie from Germany | Mabrodat | 14 | 16,826 |
07-10-2017 10:48 AM Last Post: pack |
newbie from ireland | eoinl4529 | 11 | 13,879 |
02-05-2017 02:26 AM Last Post: headrush |
