Hard Start and Rough Idle
11-28-2005, 02:05 AM
have you checked your valve clearances? i had problems starting once because all the inlet valves clearances had closed up but ince it had started the car drove fine
Run Free and take a Goodline V8FOURCAM32 MK3 Supra Patchwork AE86 from 4AGE to 7AGE to 4AGZE and now 4AGEU20v suzuki cappuccino mondeo TD |
11-28-2005, 10:01 AM
H7ERO Wrote:have you checked your valve clearances? i had problems starting once because all the inlet valves clearances had closed up but ince it had started the car drove fine Nope. I haven't since the engine has "a perfect sound" once started: No knocking, no clicking, no ticking :wink: The distributor is put in the exact position. It is NOT a tooth ahead or behing. Once started the things become better. The next starts are much better. Starts almost immedeately. There is a hesitation on idle +- 200rpm. Until the next day. The car woldn't start. P.S. In bulgarian the noun 'car' is female gender
AE86 GTS '84 Red Top |
11-28-2005, 05:04 PM
thats how it is in all languages =) regardless to the grammar..
11-29-2005, 12:54 PM
Some additional info.
Yesterday I connected E1 and T terminals of the check connector. Tried to start - no difference. However - i checked the errorcodes and it read ___||_||_||_||___||_______ - and that means TPS problem. I had previous problems with the TPS (Part No 89452-12050) and replaced it with a TPS from a BigPort Redtop (Part No 89452-12040). It worked OK. I don't think this is the problem for the hard start but I'll put the previous one for a try. AE86 GTS '84 Red Top |
11-29-2005, 06:54 PM
The problematic car:
12-05-2005, 04:05 PM
Cold start problem found. Cold start switch faulty. It worked the first time i tested it, but the next time didn't function properly. And most of the time time doesn't.
Probably it would be helpful to know that the cold start injector works only while the starter works. The afterstart enrichment is done by the 4 normal injectors and the AAV. P.S. Only the slight hesitation (+/-100 rpm) on idle remained unsolved. AE86 GTS '84 Red Top |
| Refreshed 20v blacktop first start.. | Mylesmck | 6 | 3,362 |
| Warm start problem | DJexor | 5 | 4,744 |
03-09-2023 10:15 AM Last Post: Ivan141 |
| No idle below 2000 rpm rich running | Steller Engineering | 3 | 3,464 |
| Engine starts/revs but no idle | GenkiMotors | 17 | 13,373 |
| exhaust odor/idle MOT issue | Ryo | 7 | 10,676 |
