Hall sensor
09-12-2013, 12:41 PM
Hall sensor
I have just completed an AEM ems installation into my '86 and I would ideally
like to use hall effect sensors in the distributor.
(I know that the accepted way of doing this is to run a trigger wheel on the crank pulley)
Anyone know if it has been done before or from which cars I could salvage some sensors to give it a try.
Thanks
12-31-2013, 01:22 AM
Hall sensor
most people just go trigger wheel. t3 do a wheel and pulley setup. very tasty
12-31-2013, 11:41 AM
Hall sensor
totta Crolla Wrote:I have just completed an AEM ems installation into my '86 and I would
ideally like to use hall effect sensors in the distributor.
Is there some reason why you don't want to use the VR sensors already
inside the distributor ? I'm using a GZE CAS for crank/cam positioning
signals, and the sensors are exactly the same as found in the base of a
dissy. Largeport and smallport have different setups, but both can be used.
Cheers... jondee86
12-31-2013, 12:59 PM
Hall sensor
Cheers... jondee86
Generally people have more success with the AEM when using Hall sensors as opposed to mag sensors.
The GZE CAS is probably better than a distributor because there is no HT voltage in close proximity to the sensors.
This was quite an old posting and I have decided to go COP using the stock sensors in the distributor.
Thanks
02-27-2014, 01:57 PM
Hall sensor
Hello help me please
02-27-2014, 11:25 PM
Hall sensor
Egor23 Wrote:Hello help me please
Try and keep your head above water... I'm sending a lifeboat Tongue
Cheers... jondee86
02-28-2014, 10:07 AM
Hall sensor
Respect! epic!
Big Grin map sensor cheating? fdsjakl890 8 4,071 08-26-2025 01:12 PM
  Lambda sensor wiring sam3007 10 9,483 05-23-2022 10:00 PM
Last Post: The Doctor
  AE86 Engine Coolant Temp Sensor izanagi 8 24,862 09-06-2014 05:47 PM
Last Post: izanagi
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 14,479 10-25-2013 05:13 PM
Last Post: Apsogos
  1/8 BSPT adapter for oil pressure sensor Dino86 4 9,581 06-15-2013 12:34 PM
Last Post: S.K.
