Hall sensor
09-12-2013, 12:41 PM
Hall sensor
I have just completed an AEM ems installation into my '86 and I would ideally
like to use hall effect sensors in the distributor. (I know that the accepted way of doing this is to run a trigger wheel on the crank pulley) Anyone know if it has been done before or from which cars I could salvage some sensors to give it a try. Thanks An analogue brain in a digital World |
12-31-2013, 01:22 AM
Hall sensor
most people just go trigger wheel. t3 do a wheel and pulley setup. very tasty
12-31-2013, 11:41 AM
Hall sensor
totta Crolla Wrote:I have just completed an AEM ems installation into my '86 and I wouldIs there some reason why you don't want to use the VR sensors already inside the distributor ? I'm using a GZE CAS for crank/cam positioning signals, and the sensors are exactly the same as found in the base of a dissy. Largeport and smallport have different setups, but both can be used. Cheers... jondee86 |
12-31-2013, 12:59 PM
Hall sensor
jondee86 Wrote:totta Crolla Wrote:I have just completed an AEM ems installation into my '86 and I wouldIs there some reason why you don't want to use the VR sensors already Generally people have more success with the AEM when using Hall sensors as opposed to mag sensors. The GZE CAS is probably better than a distributor because there is no HT voltage in close proximity to the sensors. This was quite an old posting and I have decided to go COP using the stock sensors in the distributor. Thanks An analogue brain in a digital World |
02-27-2014, 01:57 PM
Hall sensor
Hello help me please
02-27-2014, 11:25 PM
Hall sensor
Egor23 Wrote:Hello help me please Try and keep your head above water... I'm sending a lifeboat Cheers... jondee86 |
02-28-2014, 10:07 AM
Hall sensor
epic!
| map sensor cheating? | fdsjakl890 | 8 | 3,754 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Lambda sensor wiring | sam3007 | 10 | 8,974 |
| AE86 Engine Coolant Temp Sensor | izanagi | 8 | 24,435 |
09-06-2014 05:47 PM Last Post: izanagi |
| Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 14,244 |
10-25-2013 05:13 PM Last Post: Apsogos |
| 1/8 BSPT adapter for oil pressure sensor | Dino86 | 4 | 9,360 |
06-15-2013 12:34 PM Last Post: S.K. |
epic!
