Halfshafts
09-22-2007, 07:55 PM
Halfshafts
Can anyone tell me if it's possible to fit later type halfshafts to an early axle. I have been offered a TRD diff but it is the large shaft type so will this fit into my early axle with the larger shafts ?
Also my standard diff is working fine, is it worth changing to a TRD 2 way ?
Thanks, RS
09-22-2007, 09:37 PM
Halfshafts
Im pretty sure you can fit later type axles in an early type housing. But you also have to use later type diff head. So early axles are not compatible with later type heads just as later type axles are not compatible with early heads.Housings are the same though.
