HOWTO: Mazda FC3S 4pot Calipers
07-03-2005, 03:55 PM
I'm not too worried about the rears either. I've seen a few japanese ae86's that had r32 skyline calipers on the back (Iida Akira and Keichi Tsuchiya I believe). But my rear calipers actually lock up better than my fronts at the moment. I think my problems mostly come from the brakepads and master brake cilinder (can never get that damn brake pedal rock hard).
07-03-2005, 04:09 PM
If you upgraded only the front calipers, and not using brake bias adjuster, the stock rear brakes will lock up.
07-03-2005, 04:26 PM
I cleaned everything and put in new rubbers in all the calipers. My master brake cilinder also has new pistons, the car still doesnt brake properly though. Maybe my MBC is still leaking internally, or my brake bias adjuster isnt working right.
Anyway, this topic is not about my brake probs but about FC calipers. I still prefer the idea of euro carmaker brakes though, like the volvo Girling 4-pot calipers. Nothing against the FC but you dont find those calipers a lot around here. I have also seen some weird setup with Ford Escort RS2000 turbo calipers on senna's car, which also have lots of aftermarket support. FABRICA MI DIEM, PVNC! |
05-23-2007, 08:28 PM
sorry to be a bother, but i was serching and came acroos this. can u send the file for cnc cuttin? i been tryin to find this for months. i have the calipers. only question i have is what rotors do u guys use?
07-05-2011, 07:26 PM
this really good thanks for taking the time to share it
i just bought a set of rx7 4 pot calipers just need a set of brackets and disks what disks do you need to use with these brackets honda civic or mini cooper ??? thanks for you help toyota MR2/wright off subaru impreza non turbo/sold subaru wrx sti type R 320 bhp/sold 88 opel omega/scraped ford mondeo/scraped current car 83 AE86 levin turbo |
07-05-2011, 09:28 PM
TURBO-AE86 Wrote:what disks do you need to use with these brackets honda civic or mini cooper ???MINI cooper
07-05-2011, 09:58 PM
thanks bud ,they are a 5 stud ??? have get them re-drilled rite ???
07-06-2011, 07:54 AM
It's an old thread but I'm able to do 3D drawings in solid edge as well and can save them in a lot of formats. So if anyone needs something i might be able to help!
07-08-2011, 02:07 PM
you can use these brackets but maybe they wont fit under most 14" rims???
i used some ajps caliper brackets and redrilled eg civic discs.... but 2 things to consider is rim backspacing and interference with lca on disc caused by rcas. i compremised and milled a shorter rca also run 20mm spacers to clear 14x8j -12 ssr rims, i used fd calipers but i dont think it matters stock brake master is ok, rear brake upgrades are sumtimes strange/ maybe use ya brake pad selection to help with bias?? i had planned on using s3 rx7 setup but used s13 discs with factory caliper, its was prety easy to setup |
01-27-2013, 01:15 AM
Hi all.
I have a few questions about brakes. 1. If you put the caliper rx-7 fc3s and 276 mm mini cooper s disc problem installing 15 "wheels may be seeing?? read somewhere that not all 15 wheels will be on on the this brake kit. Minds? 2. How to install the same calipers but the disc 262mm from Honda Civic eg5, 14 discs are Good? Maybe someone use this set? 3. To install the need special adapters (brackets). I found their drawings. but the question is which of the adapters for the drive from mini cooper s, and that for the brake disk from Honda Civic. In theory they should be different, because of the Honda Civic 262mm disc is smaller , and the adapter must be smaller that the caliper to sit closer to the center. Am I right? Drawing for Cooper S 276mm rotor i found: Here: http://www.aeu86.org/viewtopic/sharing-k...hlight=rx7 Here ![]() but drawing Adapter for Honda Civic 262 mm brake I did not find. Tell me where to look? |
| Brake calipers identification | FanIsHere | 4 | 7,086 |
10-23-2020 11:45 PM Last Post: FanIsHere |
| RX7 Calipers with Rota Grid V ET0 15x8' | pack | 11 | 18,425 |
02-06-2015 11:28 AM Last Post: mad.matt |
| 4 pot rx7 calipers | Petros AE86 | 17 | 24,535 |
02-20-2012 09:39 PM Last Post: Jimmi The Kid |
| Golf Mk4-AudiA4 calipers on rear | Dino86 | 3 | 7,215 |
11-02-2011 05:30 PM Last Post: filh |
| mazda rx7 wheels | Roger | 2 | 5,858 |
05-27-2011 05:45 PM Last Post: Roger |
![AEU86 AE86 - HOWTO: Mazda FC3S 4pot Calipers [Image: AEU86 AE86 - HOWTO: Mazda FC3S 4pot Calipers]](http://a.d-cd.net/528f0fu-960.jpg)
