HELP ME. URGENT!
06-13-2005, 02:05 PM
HELP ME. URGENT!
I'm having some serious trouble getting through to Fensport Angry
06-13-2005, 02:50 PM
HELP ME. URGENT!
Did you try calling them?
I did some business with them a little while ago and they were pretty okay in responding..
06-13-2005, 02:53 PM
HELP ME. URGENT!
Jezza,
fensport can be busy but they are ok, don't forget that they add vat and delivery on top of their prices.
If you have the time you can rebuild your calipers, toyota sell the rebuild kit at around £20, there a couple of fiddly bits but i managed mine ok.
I guess it depends on how much of a hurry you are in
[Image: AEU86 AE86 - HELP ME. URGENT!]
06-13-2005, 03:08 PM
HELP ME. URGENT!
Unfortunately the pin in the N/S Caliper is the incorrect pin and the right hand side just isn't budging. I'm not sure whats involved in terms of rebuilding Calipers and I wouldnt have a clue where to start so I think just ordering the calipers would be the easiest solution (If Fensport would answer Tongue )
How long would you say the rebuild takes roughly?
06-13-2005, 03:37 PM
HELP ME. URGENT!
Once i had mastered the technique on the first one, the second took no time at all, the main problem is getting the internal snap ring in place without Toyotas special tool.
You can avoid that learning curve because i can give you the tips.
What tends to happen to them is that the handbrake mechanism siezes and that stops the brake from working. I believe it is a steel pin through an aluminium housing so there is a problem with disimilar metals.
There have been a few occasions where the garage has sorted the handbrake for an MOT only for them to stop working within a couple of miles.
06-13-2005, 03:39 PM
HELP ME. URGENT!
So the kit might not be of any use to me if I dont have the correct pin?
EDIT: I Finally got through to Fensport and they dont have any in stock Crying
What number should I call Toyota on for the Re-build kit?
06-13-2005, 05:15 PM
HELP ME. URGENT!
I called Toyota for the re-build kit, yet whats in the kit isnt substantial enough for the problem. Apparently the mountings need replacing as does one of the pins in the left caliper (it's the incorrect pin thats in there) so a whole new set of rear calipers are needed. If anyone happens to see any second hand pop up anywhere then let me know, since to get them from Toyota is going to cost me roughly £300 Huh
06-13-2005, 05:28 PM
HELP ME. URGENT!
Yeah new they are overly expensive, you really need to get some of the scrapyard.
I have some old rusted ones in the shed but I doubt those will be of any help, probably wont get you any further then you already have. Not to mention the shipping costsSad
Someone must have an extra set from a spare axle? Why dont you give that guy a call that bought that racing school with 10 ae's? Maybe he's willing to part with a set....
06-13-2005, 05:45 PM
HELP ME. URGENT!
Thats a good idea, I will have to have a word with him. I'm still remaining hopeful that someone will point out another Toyota with the same Calipers
06-13-2005, 06:01 PM
HELP ME. URGENT!
You should give Peter Moller a shout..he had a pair of brand new ones for sale a while ago..dunno what their gonna cost shipped and all though..
  Urgent replies needed DIFF OIL + refresh Okami 6 8,912 06-17-2012 09:56 PM
Last Post: Okami
  Need urgent help strut mounts. ditn 5 10,093 01-21-2012 03:37 PM
Last Post: ditn
  URGENT: Need electric help, injectors not fireing ZaX 13 21,871 07-05-2011 01:10 PM
Last Post: Nomuken
  Urgent Levin hood question... measurements and weight Okami 8 18,183 03-15-2011 11:36 PM
Last Post: Gtsi-R
  Urgent. AE86 Door hinge bolt numbers. Need help hachirokuGTV 2 7,046 09-19-2010 08:16 PM
Last Post: hachirokuGTV
