Gtsi-R red'n black coupé
12-23-2008, 04:10 PM
Post: #101
so.. been a while since I have posted here!!
but lots happend. got some nice goodies in! A TRD 2-way diff! ![]() ![]() ![]() ![]() Krownwheel needs to be replaced by my origional ![]() ![]() ![]() ![]() Diff bearings .. all 4 of them... ![]() and two sets of wheel bearings.... ( just found out they are the wronge ones... ) ![]() ![]() 176mm supercharger pully ![]() ![]() my lateral bar ![]() white shift knob ![]() ![]() PU busching set!! now to find out where it al belongs!! bought a Master and slave klutch Cilinder! also on his way to my place... Greddy Coiloverset.. front 8.0K-L200mm /rear 6.0K-L160mm ![]() whent to the garage today to change the diff and all bearings.. had a giant struggle with the axles.. them they were hard to take out!!! ![]() and found out that I had the wrong wheel bearings... the ones on the car are verry wide... check the difference ![]() ![]() ![]() ![]() So hopely the right bearings are in tomorow!! to be continued! Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
12-23-2008, 06:44 PM
Post: #102
were did you buy the greddy coils?
12-24-2008, 10:06 AM
Post: #103
@ pass racing
![]() Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
12-24-2008, 05:02 PM
Post: #104
got the right bearings in today
![]() but couldnt work on the AE, wad to mutch other stuff to do... Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
12-30-2008, 07:59 PM
Post: #105
tomorow we will work on the AE again! the diff is gonna be replaced!
keep you informed.. Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
12-30-2008, 10:57 PM
Post: #106
Yeah, those small ones look like SR5/KE70/KP61 etc...
12-31-2008, 12:15 AM
Post: #107
oke thanx... got the right ones in now
12-31-2008, 07:59 PM
Post: #108
today I managed to find some extra time to dismantel the diff
![]() ![]() Diff.. all over "body shutz" ![]() got the axle of and losend the screws ![]() Tadaa... ![]() Krown and pignon look good!! ![]() pretty empty though... ![]() old vs my new in the back ![]() ![]() after disasembly ![]() after some time and bit of hard work the pignon came loose too. ![]() Close up of the Pignon.. ![]() and the house.. cleaned.. al the stuff in the back was on the house.. Pignon is allready placed back with new bearings !! rest of the work is for some other time!! Cheers Roel Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
01-29-2009, 08:21 PM
Post: #109
Zooo,
old bearing removed and replaced, the TRD diff installed and adjusted. ![]() ![]() ![]() krownwheel needs to the pignon 0,1mm play, verry accurate work! but did work nicely. bearings mounted again. diff mounted in the car, next are the axles. ![]() removed the old bearings, but those were nasty basterds!!! axles cleaned and new wheel bearings mounted. and putted back in the rear axle. looks a car again ![]() inbetween painted the floor of the shed of a friend of mine.. in this shed the AE wil be cleaned against rust!! ![]() Some nicely fixed rear disks and new pads. also the Kroon LSD oil in. ![]() ![]() Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
01-29-2009, 08:24 PM
Post: #110
some new arrivals in!!
![]() ![]() ![]() ![]() ![]() ![]() ![]() Do I need to say more... ![]() ![]() already mounted! ![]() ![]() ![]() ![]() realy nice fit!! easy to instal ... great quallity !! Verry happy with it! Cheers Roel Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
Corolla GT Coupe - Royalty Black | pack | 266 | 308,032 |
01-12-2024 12:07 PM Last Post: pack |
Red over Black UK Ae86 | RobH69 | 5 | 18,821 |
02-03-2011 02:01 PM Last Post: Bean |
my 1984 red over black corolla gt | davegtcoupe | 3 | 11,322 |
10-12-2010 08:14 PM Last Post: davegtcoupe |
RaceMinded satin black Toyota Corolla AE86 Levin Coupe | RaceMinded | 22 | 35,277 |
Red panda coupe...rebuilded | vladx_kc | 98 | 109,524 |
07-24-2008 07:08 PM Last Post: robokill |
