Fuel Tank Modification
08-11-2014, 06:16 PM
Hi!
Has anyone ever modified their fuel tank to minimise fuel starvation under heavy cornering with less then half tank of gas? I've always had this problem in my car and recently my gas tank went rotten and I've sourced another from a AE85. It's interiour is even less divided and fuel starvation is a lot worse. I'm not fond of installing another fuel pump and a swirl pot, so I'm looking for a cheap solution with a stock gas tank. The ideal solution would be building a small recipient that could be installed around the stock fuel pump assembly without the need to cut the stock fuel tank. Any input will be appreciated. Regards |
08-11-2014, 06:59 PM
(This post was last modified: 08-11-2014 07:12 PM by Ivan141.)
The neatest solution would be to install an in-tank fuelpump-in-plastic-swirlpot assembly from a more modern car. But it is never going to happen without some cutting and welding.
Example: http://www.nastyz28.com/forum/showthread.php?t=228464 [Edit] Above post uses a 99-02 Camaro LS1 (5.8 v VW used something similar on later golf GTI's and I'm sure many other manufacturers do. FABRICA MI DIEM, PVNC! |
| bubbles in expansion tank? | fax0815 | 5 | 8,337 |
04-28-2017 04:57 PM Last Post: fax0815 |
| OEM LSD modification | malejyetti | 40 | 65,726 |
06-23-2016 12:34 PM Last Post: pack |
| Pressure gathering in fuel tank | Apolan | 9 | 18,995 |
05-18-2014 06:18 AM Last Post: chenfon |
| All I should know about suspension before any modification | damusto | 20 | 27,885 |
| plastic fuel tank | bakonick | 12 | 16,535 |
12-26-2012 12:08 AM Last Post: bakonick |
