Fuel Pump wiring
05-22-2008, 06:36 AM
Fuel Pump wiring
Does anybody know how to wire the fuel pump to the car without a GTS rear harness?
I have an SR5 rear harness. Thanks |
05-22-2008, 07:24 AM
Fuel Pump wiring
plus from ignition key to pump. pump to ground.
Don“t Think About The Past, Live In The Present And Dream About Tomorrow |
05-24-2008, 06:17 AM
Fuel Pump wiring
Great. Thanks.
Im sure we can figure it out, but if anybody knows off hand: where do we wire the plus to specifically on the ignition switch? |
05-24-2008, 07:12 AM
Fuel Pump wiring
The fuel pump only adds one wire to the SR5 rear harness.
If you follow the EWD diagrams it is really easy. http://www.aeu86.org/index/technical-ae8...topic=5158 Do it properly with a circuit open relay, which you can pickup up from any 80's EFI Toyota at the wreckers. Don't forget to grab the plug with a fair bit of wire, then join as required. |
| Tail light wiring... | Mylesmck | 4 | 3,474 |
02-02-2024 12:36 PM Last Post: Mylesmck |
| 20v BT - which oil pump? | Mylesmck | 4 | 5,531 |
| Lambda sensor wiring | sam3007 | 10 | 8,838 |
| Fuel pump issue | DJexor | 11 | 10,470 |
| 4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 9,964 |
06-20-2019 11:38 AM Last Post: Lykowsky |
