Fuel Pressure regulator
05-07-2005, 11:06 PM
Post: #31
I had a look at my stock fuel regulator : It's not attached to a vaacum source . There are only two hose , one to the injectors rail , and the other comming from tank ....??any idea
Filh
Filh
Save the RWD cars
05-08-2005, 10:49 AM
Post: #32
You could put a t-junction in the vacuum line that goes to the econometer, or just sacrifice the econometer and use it's vacuum line as a dedicated source. It connects to one of the 3 vacuum terminals at the back of the intake manifold. I think that should provide a perfectly good vacuum source..
05-08-2005, 08:08 PM
Post: #33
oh thanks. I 've noticed a unused vaacum source , near the throttle body
i'll try it .
thanks
filh
Filh
Save the RWD cars
05-09-2005, 12:47 PM
Post: #34
The hose within the screw for adjusting is vac/boost one.
The opposite is for fuel returning. The side one must be connected to the fuel rail.
PS: If you turn the regulator 180 angles (top goes bottom) - the things will be easier Smile
05-09-2005, 07:58 PM
Post: #35
Thanks guys , you helped me a lot with your advices .It's now clear how to fix that FPR. Hope it will work.
Thanks
Filh
Filh
Save the RWD cars
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 25,722 08-19-2018 12:08 PM
Last Post: AlexKTM
  4AGE Fuel Regulator Alex170984 6 12,818 02-24-2016 05:59 PM
Last Post: totta Crolla
  Oil Pressure Query Alex170984 2 6,708 12-11-2014 01:25 AM
Last Post: Alex170984
  Pressure gathering in fuel tank Apolan 9 19,030 05-18-2014 06:18 AM
Last Post: chenfon
  oil pressure high kawo 17 25,948 09-29-2013 12:06 PM
Last Post: allencr
