Fuel Cell Install. Questions
07-24-2007, 06:07 PM
Hey guys. Im installing a fuel cell into my ae86 to race in mini stocks. I just dropped the tank last night, and was wondering why there were 3 fuel lines going to the tank? Im guessing one's a feed, and another for return, but what would the third one be? Its a carrburated 1.6 Thanks for any help.
07-24-2007, 06:09 PM
Rear brakes!
[Image: AEU86 AE86 - Fuel Cell Install.    Questions]
Cump´s
Filipe Oliveira
07-24-2007, 06:11 PM
Into the fuel tank??
07-24-2007, 06:20 PM
Then should be the "breather", conects from the tank to a thiny piece located at the panhard bracket.
Cump´s
Filipe Oliveira
07-24-2007, 08:29 PM
kind of figured it was a breather. Thanks. One more question, would it be safe to put both the return and feed line going into the same hose? I have a fuel cell that only has 1 hose comming out, so i was thinking of doing a 2 into 1.
07-24-2007, 10:31 PM
Or you could look for something like this...
http://cgi.ebay.co.uk/eBayISAPI.dll?View...0133097825
Then you don't need a return line Smile
Cheers... jondee86
07-25-2007, 03:45 AM
thanks for that jon, but i still need to know.
07-25-2007, 09:16 AM
Simple answer is YES Smile
If you want your fuel to circulate and maintain pressure in a fuel rail,
using a FPR, just like the stock EFI setup, you can do it. Using an external
pump drawing from the single fuel cell outlet, tee the return into the line
between the cell and the pump. The pump will take the return flow plus
whatever it needs from the cell.
This link covers a couple of drawbacks with such a system :
http://www.findarticles.com/p/articles/m...i_n9426858
Since you will be using an external pump, there will not be any special
problem with filtering, and the standard filter in the engine compartment
will be fine Smile
Cheers... jondee86
07-26-2007, 06:45 PM
Thanks again jon. It's a carburated system tho.
07-27-2007, 10:25 AM
I knew that.... Undecided
The only real difference between an EFI fuel system and a carb system
is that the EFI rail pressure will be 30-40 psi and for carbs you only need
2 or 3 psi. So you need to change out the EFI pressure regulator for a
suitable low pressure one. This can be mounted by the engine, or back
by the fuel cell (just make sure all your hoses have clamps).
The EFI rail can be modified to feed the carbs by blocking up the injector
holes and tapping in hose connections. Makes a nice tidy installation, and
the fuel feed line can be used as it is Smile
Cheers... jondee86
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 8,282 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 4,424 04-30-2024 09:46 PM
Last Post: Mylesmck
  Brake Bias Questions mad.matt 10 16,200 01-03-2019 04:54 AM
  CD player install. kazi 8 12,493 02-21-2017 11:57 AM
  wider rear axle,track width,suspension questions ditn 6 12,699 10-18-2016 11:50 AM
Last Post: fantapants
