Foam-ectomy on OEM Seat
02-16-2017, 01:30 PM
Hi Guys,
With my build, I will be replacing the drivers seat with a Fixed Back bucket seat but don't want the original seat to go to waste. The current original seat (light/dark grey JDM) has adjustable bolsters to hold you better but the driver's seat fabric has seen better days, as has the foam. The passenger seat is in better condition from a fabric perspective. Would it be feasible to fit the drivers side seat "shell" (for lack of a better phrase) into the passenger side, after having the foam refreshed and the seat covers swapped over? I would like the passenger to have a bit more support while retaining a reclining seat if I do a longer trip and have to sleep in the car ![]() (I can't remember if the passenger side has adjustable bolsters or not so let me know if it does hah) Also, has anyone had any luck with repairing the seatbacks? Many Thanks! Matt |
02-16-2017, 02:13 PM
I believe that the adjustable boister is only on the drivers side. [might be different? USA Vs EU] The easiest solution would be to just change the seat backs and swap the reclining mechanism for side to side. To remove the cover on the seat back, the only trick is removing the cylindrical barb fittings that hold the head rest. You have to lift the cover up and with a pair of needle nose pliers, stick the tips through the seat foam and compress the bottom of the plastic brab to extract these fittings. You should then be able to remove cylindrical barbs and the rest of the upper seat cover. Dave W
02-17-2017, 12:22 AM
Thanks Dave, it's been ages since Ive even looked at mine hahah.
I'll give that a bash. |
| Bucket seat prices | gh0st | 5 | 4,833 |
01-23-2022 11:44 PM Last Post: AlexKTM |
| Rear Seat Belt Question | sleepercivic | 5 | 12,343 |
06-29-2017 09:30 PM Last Post: banpei |
| got seat belts. but they rolled up | MC_JP | 8 | 12,565 |
05-06-2014 04:04 PM Last Post: banpei |
| AE86 seat belts... | Okami | 11 | 19,375 |
09-27-2012 08:55 PM Last Post: banpei |
| Sparco chrono road seat rails | stratosTRD | 6 | 9,495 |
09-03-2011 07:32 PM Last Post: stratosTRD |
