Final drive
11-26-2004, 01:13 AM
Final drive
Guys, I have another problem. My final drive pinion gear has broken and I need to find a replacement. Since new ring&pinion sets are quite expensive I was wondering if anyone has a spare axle with good final drive gears. Also, I remember someone mentioning that ring&pinion on some Lite-ace's (or something) fit the ae86, maybe someone could tell me a bit more about that?
He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which. |
11-26-2004, 01:23 AM
Final drive
rear axle of the liteace aint that difrent i think i think it could be the same as the SR5 so same as on the ae86 without discbrakes
its hard to find and expensive to buy Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
11-26-2004, 01:43 AM
Final drive
Good excuse to change your R&P to a lower gear. Or is 300 Euro's really out of the question?
11-26-2004, 02:14 AM
Final drive
@aico: and then i would look for a Final Gear Ratio: 4.7?
http://www.stageoneimports.com/main.pl?s...TPS-02C001 if i would go for a liteace, would i go for the one with the 4.6 or 4.8 ratio? (which one shortens the drive-train and gives the quickest accelleration?) He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which. |
11-26-2004, 09:15 AM
Final drive
I think 4.8 would give the shortest ratio..(BTW, shortens the drivetrain is a bit to literally translated)
11-26-2004, 12:49 PM
Final drive
From the site 4.7 is the fastest acceleration. The cheapest also. The difference between 4.7 and 4.8 is almost nothing. Just go for the one you can get.
You're leaving the engine almost stock right? Because if you're making high HP or a very high rev limit a higher gear would be better. |
11-26-2004, 02:21 PM
Final drive
for sure i'm going to do an engine swap and then tune it, later....................
11-26-2004, 03:55 PM
Final drive
The lower the final gear the more you have to shift. When you have more power you might have to shift too often. Personal preference.....make up your mind about what you want.
It's only about a 10% difference so it ain't that much. TRD has an even lower gear if I recall correctly is was about a 20-25% difference. You really need a very high revving engine if you want to get a final gear like this. |
| Final drive calculation. | Aram | 31 | 45,766 |
12-24-2014 03:08 PM Last Post: Uzelac |
| Gear end , drive pinion height | filh | 5 | 15,048 |
06-27-2013 12:29 AM Last Post: filh |
| 5.375 final drive ratio with stock T50 | 4000GT | 23 | 36,092 |
08-07-2012 01:08 PM Last Post: 4000GT |
| Final Drive ratio - need advise | KD2229 | 12 | 22,220 |
08-26-2011 08:33 AM Last Post: totta Crolla |
| U-joint on drive shaft - Beams 6s box | KD2229 | 3 | 7,002 |
08-18-2011 03:59 AM Last Post: KD2229 |
