Fensport 4age superchip
01-28-2009, 10:19 PM
Whilst the software will allow downloading of different maps to suit different engines it will also allow changes to the base map. On some engines although sadly not the 4AGE you can modify the rev limit too.
This unit is for ignition only and is designed to work with the original ECU
02-02-2009, 01:59 AM
Totta crolla,
Thanks for all the info. I stumbled upon this via google. Its really helped me out.
Cheers Thumbs up!
02-03-2009, 10:58 AM
Thumbs up!
02-03-2009, 05:07 PM
^^ Totta will probably chime in, but make sure your 12v+ switched source is live while the car is cranking over. Y'know how accesories like the stereo and lights don't work while cranking the engine.
You're probably aware of this already... Just incase though...
02-03-2009, 08:58 PM
ill think about that...
02-03-2009, 11:38 PM
Yeah, I do have an ICON Race, but it is on my Subaru Confused Same crap eh?
I wish i had another direction for you... Do be carefull though, if you have constant power to the coil for too long without it discharging, you can pooch the coil. Had this problem with an ill installed piggyback.
Good luck.
09-06-2009, 12:34 AM
Hello everyone, New-B here
Sorry this has to be my first post but I was linked to the site from Google following a search for the Superchips Icon.
I have the chip but need a copy of the software, does anyone have it which they can email or send to me by cd?
my email address is [email protected] - any help as to where I can get this from would be appreciated.
Thank you
09-22-2009, 09:37 AM
http://www.segilu.com/Summer2001/index.htm
You can download everything except the spark maps.
Above you will find the wiring for the Toyota 4AGE Superchip.
they are password protected under a folder on the e-tuning (superchip dealer) website.
Unit needs b+ and E01
The other two wires must be spliced into IGt to completely intercept the signal, not piggyback.
Looks like superchips probably just increase dwell for more spark?
With no rpm reference they cant be altering timing, unless its looking at number of incoming Igbt/min...hmmmm....
http://www.skynet.ie/~eireae86
  Black Diamond Brake Lines - Fensport parrot 6 11,240 08-30-2010 12:53 AM
Last Post: parrot
  4age (87-89) engines at Fensport dreja 11 15,198 01-30-2005 09:37 PM
Last Post: gon
