Fallguz's small project
03-19-2007, 11:02 AM
Hey,
I'll be updating this thread with photos and such, because a few parts will be arriving shortly.
Note that I want to keep this AE86 streetable, so there won't be excessive modifications. Wink Here is the list of parts that will arrive this week. Installation will follow shortly after. I wanted to keep the car stock for longer, but with the Nürburgring meeting coming up, these could save my life. Wink
Already installed:
Celica-Supra wheels on Dunlop SP9000 rubber
20mm spacers on the rear
Cusco Copper Clutch kit with lightweight Flywheel
To be installed:
TRD Quick Shift Lever Set
TRD Brake Pads black version (Front)
TRD Brake Pads black version (Rear)
Techno Pro Spirit Front Brake Rotors
Techno Pro Spirit Rear Brake Rotors
TRD Brake Fluid
TRD Suspension Bush Set
Cusco Adjustable Rear Lateral Rod
Cusco Front Roll Center Adjusters
CUSCO Adjustable Front Pillowball Upper Mounts
TRD Front 8-way Adjustable Shock Absorber Cartridges
TRD Rear 4-way Dampen Adjustable Shock Absorbers
TRD Low Height Spring Set front
TRD Low Height Spring Set rear
Redline Tail Lights
HKS Legal Cat-back Exhaust System
Please note that after these parts, the car / project should already be finished for me. I really do not plan to start another bottomless money pit. Wink
Recent photos with the supra wheels. (thanks to my friend DonThomaso for the leet photographic skillz & camera)
03-19-2007, 11:31 AM
nice hachi, and great photography! Hurray!
03-19-2007, 11:50 AM
Nice pics! Thumbs up!
Any change we may set them as wallpapers? Tongue
[Image: AEU86 AE86 - Fallguz's small project]
03-19-2007, 12:45 PM
banpei,
is there a wallpaper section now? You can surely use them as wallpapers if interested.
Do you need higher quality of both pics?
by the way: the guy who took these pics will be in my passenger seat at the Nürburgring meeting - so there will be nice pics of our hachies. Big Grin
03-19-2007, 06:20 PM
Hmmm, wallpaper section disappeared some time ago during the upgrade... We will add that section again later. Tongue
03-20-2007, 02:08 PM
banpei,
I have changed the pictures in my first post to high resolution. (ca. 3000 x 2000)
On a related note, my parts should arrive this week, so hopefully in the next week or so I can upload the pics of the modding! Hurray!
03-20-2007, 02:30 PM
Thanks for sharing Smile Thumbs up!
03-21-2007, 12:51 PM
Thanks! Thumbs up!
03-31-2007, 07:37 PM
Update / Problem Sad
Pics will follow, but at the moment i'm having troubles and would like to know if anybody has an idea:
All the parts are installed now, but when installing the TRD springs and shocks, a nasty noise started appearing:
When driving around (speed doesn't matter much) whenever I drive over a bump (even small ones) i'm getting a pretty loud *thud* (sounds metal on metal) from the front right wheel somewhere.
replaced were: dampers, springs, brake pads and brake rotors and Upper mounts.
It sounds like two coils of a spring hitting together, but i doubt that is the problem. (not sure really)
It happens not at every bump, but very often. What's interesting: When I leave the car standing for a while (10 minutes or more) the noise is not audible until I have driven a few minutes. Then it starts over again and sounds like i'm running broken suspension on the right..
The dampening, and road feel is great. Feels absolutely stable even at the limit. It just sounds scary.
We have already taken out the springs, etc. 2 times and checked everything. Also checked if there's a worn bushing, and if the wheel bearing is still good.
I know the pillowball upper mounts can transmit noise, but it really sounds like something is loose, and upper mount noise sounds different than that. I honestly wouldn't want to drive on the Ring with that noise, gives me the feeling that the right spring could fall out or something Wink
Any other ideas? I have RCA's lying around, could these help if the springs are really 'moving around' slightly when driving?
edit: one more thing - the springs are not really short, they only dropped the car 2-3 cm.
03-31-2007, 09:43 PM
have you checked if the brake system is all good and tight?
  4age small port engine build sketchy 8 15,396 04-07-2013 09:37 PM
Last Post: sketchy
  Small port 16v with F/A internals harkes 5 12,019 08-18-2012 02:12 PM
Last Post: BOOMEX
  Greek hachi small project ts@n@k@s 19 28,857 03-11-2009 11:50 AM
Last Post: dikolotour
  AE86 - Small project hinachyo 11 19,872 04-28-2007 01:31 AM
Last Post: hinachyo
  New Greek Hachi + Small Project dikolotour 23 29,248 03-14-2007 05:55 PM
Last Post: Dorito86
