Fagwmenoi ekkentroforoi
04-25-2007, 10:26 AM
έχει καπελότα με πλακίδια ρύθμισης (αλά Μιραφιόρι παλιά
Άκη αλλά την "μαγκιά" πρέπει να την έκανε ο καγκουρομάστορας στην ρύθμιση... μάλλον τις έκανε Αλαιν-ντελόν ρύθμιση αντί για ακριβείας και με κρύο μοτέρ...
AE86 FANATIC!!! |
04-25-2007, 10:58 AM
κι ένας χρήσιμος πίνακας ... :wink:
4A-GE 16V Camshaft Comparisons: Duration Lift Intake opening Exhaust opening Comments 232 7.1mm 8BTDC 47BBDC Stock 4AG(Z)EU used on 90~91 Hi-comp. AE92 and supercharged AW11. P/N Intake 13501-16030. Ex. 13502-16020, Good turbo cam. Keeps exhaust pressures high without blowing back though intake manifold. 240 7.56mm 9BTDC 51BBDC Stock 4AGEU used on AE86 and AW11. P/N Intake 13501-16010. Ex. 13502-16010. Some have found good power setting the maximum lobe lift for the exhaust at 100BTDC and intake at 100ATDC. For more bottom end power retard the exhaust 4 and advance the intake 3. For more top end, advance intake 4and exhaust 3 from stock settings. 244 .322” Web – p/n 45-082, Grind number 294; Duration @ .050” lift is 218. Increases overall power. Ground on new billet cams. Works with factory injection or carburetors. (8.2mm) 248 7.45mm HKS - p/n 2202-RT030, Can be used on 4AGZE 250 .350” Web – p/n 45-092, Grind number 101; Duration @ .050” lift is 228. Increases mid and upper RPM power. Ground on new billet cams. May cause fair idle on fuel injected engines. (8.9mm) 256 7.6mm TRD - no longer available. Good bottom-end power and plenty of mid-range for passing. 256 7.9mm Toda - p/n 02.TD.CS4AG0S1 256 8.35mm HKS - p/n 2202-RT031, Can be used on 4AGZE 256 8.5mm Toda - p/n 02.TD.CS4AGBF2, Recommended to use Toda’s valve train kit, i.e., under bucket shims 256 9.0mm Toda - p/n 02.TD.CS4AGCJ1, Recommended to use Toda’s valve train kit, i.e., under bucket shims 257 .398” Web – p/n 45-131 (Hard-weld), Grind number 286; Duration @ .050” lift is 226. Designed for off-road and stadium racing. Requires under bucket shims. (10.1mm) 264 7.6mm 26BTDC 68BBDC TRD - no longer available. Increased performance, needs headers, more performance with higher compression. Mfg. recommends setting the cam at max lift for the intake at 106 ATDC and exhaust at 116BTDC. 264 7.9mm Toda - p/n 02.TD.CS4AGCJ2 264 8.35mm HKS - p/n 2202-RT032, Can be used on 4AGZE 264 8.7mm Toda - p/n 02.TD.CS4AGCJ3, Recommended to use Toda’s valve train kit, i.e., under bucket shims 264 8.9mm Toda - p/n 02.TD.CS4AGAI1, Recommended to use Toda’s valve train kit, i.e., under bucket shims 272 7.5mm TRD - p/n intake, 13501-AE871, ex. 13502-AE871. Increased performance, needs headers, more performance with higher compression, approaching limits of stock EFI, works best with side drafts. Ex. max lift set at 98 BTDC. In. max lift set at 100 ATDC. Will work with new (suggested) factor valve springs. 272 7.8mm Toda - p/n 02.TD.CS4AG0C2 272 7.9mm Toda - p/n 02.TD.CS4AG0A2 272 8.35mm HKS - p/n 2202-RT033, Using both intake and exhaust on a stock Supercharged 4AGEZ has less bottom end below 3,000, strong mid to high end power. 272 8.5mm Toda - p/n 02.TD.CS4AG0P1, Recommended to use Toda’s valve train kit, i.e., under bucket shims 272 8.7mm Toda - p/n 02.TD.CS4AG0B2, Recommended to use Toda’s valve train kit, i.e., under bucket shims 272 8.9mm Toda - p/n 02.TD.CS4AGAI2, Recommended to use Toda’s valve train kit, i.e., under bucket shims 272 9.9mm Toda - p/n 02.TD.CS4AG0P4, Must use Toda’s valve train kit, i.e., under bucket shims 272 10mm TRD - p/n ex. 13502-AE831. N2 and Rally cam has good bottom-end torque and strong mid-range, revs to 7,500 RPM. (requires race engine prep. and mod.s) Ex. max lift set at 100 BTDC 272 10.3mm Toda - p/n 02.TD.CS4AGCJ4, Must use Toda’s valve train kit, i.e., under bucket shims 276 .384” Web – p/n 45-021 (Hard-weld), Grind number 119; Duration @ .050” lift is 240. Good overall power for off-road racing. Requires under bucket shims. (9.8mm) 280 10.3mm Toda - p/n 02.TD.CS4AG0J4, Must use Toda’s valve train kit, i.e., under bucket shims 284 .395” Web – p/n 45-071 (Hard-weld), Grind number 110; Duration @ .050” lift is 256. Strong mid and upper end power for off-road racing and pro-rally. Requires under bucket shims. (10mm) 288 7.5mm 57BBDC TRD - p/n intake, 13501-AE861, ex. 13502-AE861. Very strong power increase from 4,000 to 7,000 +RPM, less bottom end (does not idle very well). Used as an exhaust cam with 304 intake in TRD rally car (max lift @ 98 BTDC). Will work with new (suggested) factor valve springs. 288 7.8mm Toda - p/n 02.TD.CS4AG0C3 288 8.3mm HKS - p/n 2202-RT034, Can be used on 4AGZE 288 8.5mm Toda - p/n 02.TD.CS4AG0P2 288 8.7mm Toda - p/n 02.TD.CS4AG0B3, Recommended to use Toda’s valve train kit, i.e., under bucket shims 288 10.0mm Toda - p/n 02.TD.CS4AG0I1, Must use Toda’s valve train kit, i.e., under bucket shims 288 10.0mm TRD - p/n ex. 13502-AE821. Rally cam has less bottom-end torque more HP on top, revs to 8,000 RPM. (requires race engine prep. and mod.s) Max lift set at 100 BTDC 288 10.35mm HKS - p/n 2202-RT035, Can be used on 4AGZE 296 11.0mm TRD - p/n ex. 13502-AE951. Used on the late model AE92 Hi-comp. Head with slightly different porting configuration. Intake max. lift set at 102 BTDC. 300 10mm 62BTDC 76BBDC TRD - p/n ex. 13502-AE811. Japanese N2 racing cam. has less bottom-end torque more HP on top, revs to 8,000 ~ 10,000 RPM. (requires race engine prep. and other mod.s). Max lift set at 102 BTDC, exhaust and 98 ATDC, intake. 304 7.5mm 52BTDC 65BBDC TRD - p/n intake 13501-AE851, ex. 13502-AE851. Japanese Group A racing cam, very strong power increase from 4,500 to 7000 RPMs. (requires race engine prep. and mod.s) Max lift set at 100 BTDC, exhaust and 100 ATDC, intake. Will work with new (suggested) factor valve springs. 304 7.8mm Toda - p/n 02.TD.CS4AG0C4 304 8.3mm HKS - p/n 2202-RT036, Can be used on 4AGZE 304 8.5mm Toda - p/n 02.TD.CS4AG0P3 304 8.7mm Toda - p/n 02.TD.CS4AG0B4, Recommended to use Toda’s valve train kit, i.e., under bucket shims 304 10mm 62BTDC 76BBDC TRD - p/n intake 13501-AE801, ex. 13502-AE801. Japanese N2 & Formula Atlantic racing cam. has less bottom-end torque more HP on top, revs to 8,000 ~ 10,000 RPM. (requires race engine prep. and other mod.s). Max lift set at 102 BTDC, exhaust and 98 ATDC, intake. 304 10.35mm HKS - p/n 2202-RT037, Can be used on 4AGZE 304 10.5mm Toda - p/n 02.TD.CS4AG0C1, Must use Toda’s valve train kit, i.e., under bucket shims 304 10.7mm TRD - p/n exhaust 13502-AE881 304 11.0mm TRD - p/n intake 13501-AE951, ex. 13502-AE901. Used on the late model AE92 Hi-comp. Head with slightly different porting configuration. Intake max. lift set at 102 ATDC. 310 10.5mm Toda - p/n 02.TD.CS4AG0T1, Must use Toda’s valve train kit, i.e., under bucket shims 312 11.0mm TRD - p/n intake 13501-AE901. Used on the late model AE92 Hi-comp. Head with slightly different porting configuration. Intake max. lift set at 102 ATDC. 320 10.0mm TRD - p/n intake 13501-AE811 320 10.8mm Toda - p/n 02.TD.CS4AG0A4, Must use Toda’s valve train kit, i.e., under bucket shims 320 11.0mm TRD - p/n intake 13501-AE881 AE86 FANATIC!!! |
04-25-2007, 12:12 PM
Ακη οταν ειχα παει να δω το αμαξι το ειχαμε βαλει μπροστα και δουλευε πενα αθορυβο ολα καλα. Δεν το ανοιξαμε και δεν ειχαμε και την πολυτελεια κατω απο το σπιτι του ιδιοκτητη να λυνουμε και να δενουμε. Τον θορυβο αρχισα να τον παρατηρω τις επομενες μερες. Μπορει να ηταν και πιο πριν αλλα να μην τον ειχα παρατηρησει, τι να πω.
Αυτο που ειχα παρατηρησει ειναι οτι ο δεικτης λαδιου ηταν στο μισο. Ο ιδιοκτητης μου ειχε πει οτι αλλαζε λαδια καθε 10.000 χλμ οποτε μπορει να την ειχε κλασει το λαδι. Δεν το πιεσα το αμαξι στο ταξιδι. Μου ειπε οτι εβαζε 15/40 και το ιδιο εβαλα και εγω στην πρωτη αλλαγη αλλα μετα το αλλαξα με 20/50 νομιζωντας οτι θα διορθωσει το προβλημα. Ειχα κανει 2000 χλμ με 15/40 και δεν ειχε κατεβει χιλιοστο η σταθμη. Τωρα με 20/50 εχω κανει 2500 χλμ και παλι δεν εχει κατεβει η σταθμη. Υποτιθεται να θυμισω οτι το μοτερ ειχε γινει επισκευη. Τωρα τι εχει παιχτει δεν ξερω. Μπορει ο Γιωργος να εχει δικιο. Το θεμα ειναι τι κανουμε τωρα. Γιωργο ωραιες πληροφοριες!!! Toyota Corolla KE30 + Toyota Corolla AE86 |
04-25-2007, 12:58 PM
πάντως ότι κι αν αποφασίσεις Διονύση θα πρέπει αφού βάλεις τους νέους εκκ/ρους ΑΜΕΣΩΣ να ρυθμίσεις βαλβίδες με παγωμένο μοτέρ ΣΩΣΤΑ!!!
Και για να γίνει αυτό πρέπει να πας σε συνεργείο που να έχει συλλογή πλακιδίων για να κάνει ΑΚΡΙΒΕΊΑΣ ρύθμιση και ο μάστορας να κατέχει και να ΘΕΛΕΙ να κάνει ακριβή ρύθμιση κι όχι ότι νά'ναι ... Ελπίζω να βοηθάω :wink: AE86 FANATIC!!! |
04-25-2007, 01:17 PM
Βοηθάς και πολύ μαλιστα!!!
05-03-2007, 08:56 AM
Ρε συ Διονυση τι έκανες τελικά;;;
05-03-2007, 09:02 AM
Έλα Άκη!!!
Μίλησα με Θανάση. Θα του βάλω τα λεφτά και θα μου το στείλει. Ελπίζω όλα να πάνε καλά!! Ευχαριστώ πολύ Toyota Corolla KE30 + Toyota Corolla AE86 |
05-03-2007, 09:13 AM
τι έγινε Νιόνιο ???? θα "αγριέψουμε" ??????????
AE86 FANATIC!!! |
05-03-2007, 09:19 AM
Οχι Τζωρτζ μαμά μένουμε για αρχή! :wink:
05-03-2007, 09:28 AM
α ρε και έιπα κι εγώ θα ακούσω και κανα άλλο χατσιρόκου να "κελαηδάει" .....
AE86 FANATIC!!! |
![AEU86 AE86 - Fagwmenoi ekkentroforoi [Image: AEU86 AE86 - Fagwmenoi ekkentroforoi]](http://img159.imageshack.us/img159/9409/39563944fwdsucksue7.jpg)
