Exhaust Size
11-07-2011, 07:35 PM
Exhaust Size
Hello, got one question. You got any idea about the original size of the piping in the AE86 exhaust?! In mm?!
11-07-2011, 07:56 PM
Exhaust Size
About 48mm.
AE86 Full Hybrid - Burns rubber and gasoline |
11-08-2011, 06:00 AM
Exhaust Size
On an OEM system, at one point after the resonator, but before the muffler... the piping goes down to 40mm, basically just before the pipe goes into the rear muffler
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-09-2011, 03:13 PM
Exhaust Size
Thanks! What would be the "ideal" piping inner size on a sports exhaust piping?!
I wanna go OEM, but at the same time, i want something that does not constraint my engine! |
11-09-2011, 04:52 PM
Exhaust Size
OEM is claimed to be good to about 180hp.. go figure.
Best bet for you is to match exactly the diameter of the headers collector exit so that there are no steps anywhere in the exhaust after the collector. A wheel to steer the front of the car A pedal to steer the rear |
11-09-2011, 06:23 PM
Exhaust Size
Well there's a good point there!
Measuring the end of the headers and build the line using the same diameter. That's what i'm probably doing! One more question here, not using the middle silencer makes the final muffler always loud?! Or it can be controled, using a good muffler? Regards |
11-09-2011, 07:32 PM
Exhaust Size
Almost always yes.. If using flow-through silencers-> definitely.
| Shim size for AM cams | kazi | 4 | 7,023 |
| Hub size | kazi | 5 | 11,799 |
| Camshaft sprocket bolt size? | harkes | 1 | 5,883 |
| Oil plug thread size is M18x1.5 ???? | Dino86 | 5 | 11,531 |
| what tires size do i need? | slowboy2 | 10 | 17,319 |
05-28-2012 09:26 AM Last Post: Uzelac |
