Eric's KE70 08/10 Longchamps!
12-08-2008, 05:59 PM
Post: #111
Offcourse i will show them Smile
Are you going to buy a KE70 in Malaysia Undecided
12-08-2008, 06:56 PM
Post: #112
If everything going smooth, I will buy an KE70 in Malaysia with 4AGE ready for my brother there. But this mean when I go to Malaysia I could drive it too Smile
12-08-2008, 07:10 PM
Post: #113
ah, you are not going to import it to the Netherlands?
03-25-2009, 11:46 PM
Post: #114
Long time no update..
Got the ae86 front crossmember in, all powdercoated and all.
engine went in for a testfit, fits like a glove!
[Image: AEU86 AE86 - Eric's KE70 08/10  Longchamps!]
Then i started working on the pedals since the KE has a cable clutch fitted and it need to be rebuild to hydraulic.
KE firewall
TE firewall
almost the same but it needs a little bit of modification. Redrill a couple of holes and when that is done i will be able to fit the TE pedals into the KE.
KE pedals, cable clutch
TE pedals, hydraulic clutch
TE has two pieces, the clutch pedal is mounted seperately.
Then i started working on the axle's..
Rusted small one is std. KE axle, yellow one ( Huh ) is from the TE/AE.
Notice the difference in diff size and rear brake size. There also is a light difference in lengt of propshaft, the TE axle is a little shorter due to the length of the diff housing.
Today i was fighting to get the T3 tracktion brackets on the TE axle, the middle hole willnot fit Banging head Banging head Banging head So ill drill the middle hole in the axle a little bit larger tomorrow and then it will fit and i can bolt the axle to the KE.
After that it is off to get the roll cage in!
04-04-2009, 07:40 PM
Post: #115
Finally: it is rolling again!
full lock,
iall adjustable T3 stuff,
i rolled it 4 meters from were it was sitting for the past 6 months Smile
rear underneath,
04-04-2009, 10:12 PM
Post: #116
Got some lock there! Thumbs up!
04-13-2009, 08:41 PM
Post: #117
Today i made holes for the master clutch cilinder:
Tomorrow i will make new holes for the brake booster etc.
And i have to find me a new clutch cilinder. I dont want to put back the old rusty thing i have now. I bought a new one from an ae86 but it has different mounting points.
04-13-2009, 08:49 PM
Post: #118
take it apart, refurbish it (buy new seals), spray it, put it back.
Finished Tongue
04-13-2009, 09:08 PM
Post: #119
No Wink
I want all new parts!
04-13-2009, 09:26 PM
Post: #120
what is that rusty thing in your last pics then? Tongue
  Eric O'Sullivan's AE2000 BenR 39 58,411 11-15-2006 12:01 AM
Last Post: Mux213
