Engine running lean
07-12-2005, 08:20 PM
Engine running lean
Hi guys, my engine seems to be running lean and is idling at just below 1000 from the moment I start the car. I know this isnt normal and was wondering if anyone could give me a bit of hepful advice on how to source the problem. Thanks Smile
07-12-2005, 09:13 PM
Engine running lean
Are you sure its running lean?
If youre going just off your low idle speed then your idle screw might be adjusted wrongly. And in my experiance, the idle speed of AE86's is never very consistant and prone to change slightly in differant conditions.
07-12-2005, 10:46 PM
Engine running lean
That's also my opinion, 1000-1300 rpm when started and 800 when the engine comes on the right temperture.
07-12-2005, 10:47 PM
Engine running lean
Running lean on idle shouldn't be bad. Just look at the idle rpm's.
Broken down 1984 Trueno HB
[Image: AEU86 AE86 - Engine running lean]
07-12-2005, 11:03 PM
Engine running lean
hehe, idle cold is 2000 rpm, idle warm is 500 rpm for meWink
07-12-2005, 11:14 PM
Engine running lean
very cold 2200-2300 RPM
cold 1500RPM
normal 800-900 RPM
very hot 500-600 RPM [driving in city jam]
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
07-12-2005, 11:18 PM
Engine running lean
2000-2000 cold and 900-1000 normal
07-12-2005, 11:38 PM
Engine running lean
Mine is 2200 cold and 1200 hot. But thats cuz i hate if the idle is to low when hot... With a idle beneath 1000 rpm, the 4AGE has a tendensy of hesitating when you startup from standstill.
07-13-2005, 09:17 AM
Engine running lean
Knudsen Wrote:Mine is 2200 cold and 1200 hot. But thats cuz i hate if the idle is to low when hot... With a idle beneath 1000 rpm, the 4AGE has a tendensy of hesitating when you startup from standstill.
Well, it's okay for me: it is not really hesitating, except when in reverse. Undecided
07-13-2005, 08:07 PM
Engine running lean
Being my first time driving the hachi in hot conditions i've obviously jumped the gun a little Blush It was a very hot day yesterday so it makes perfect sense for it to be idle at 800. I just thought the fact I topped up the oil just the other day may have had some effect. Thanks anyway guys Thumbs up!
  No idle below 2000 rpm rich running Steller Engineering 3 4,254 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Running issues sam3007 6 6,149 06-26-2022 01:34 PM
Last Post: Dave W
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 12,428 11-09-2020 10:51 AM
Last Post: totta Crolla
  Anyone running DIY Coilovers? Rasteirinho 8 17,506 11-19-2013 10:30 PM
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 11,147 10-30-2013 11:18 PM
