Engine rebuild questions
05-22-2015, 01:23 AM
(05-21-2015 11:29 AM)Alex170984 Wrote:  Cometic gasket
I am using it again as well since I've had to rebuild my cylinder head!
Yes they can be reused... BUT...
The Cometic gaskets outer layers use Viton rubber (gee see that again...) to help seal it. A fresh gasket having not been heat cycled, has to be better...... Angel
Dan -
05-28-2015, 11:14 PM
Anyone knows a NPR supplier? Can't find any through google or eBay
05-29-2015, 10:01 AM
I recommend you ask first at local auto parts store. Euro is weak and you will pay (maybe) a lot more buying from uk or outside Europe.
Grab a phone and ask
http://www.rochaecastro.pt/pt/catalogo/m...ne-npr-sm/
05-29-2015, 07:12 PM
we dont have such things in spain, just spoilers, rims, decals, etc :/
05-29-2015, 07:17 PM
I thought you were Portuguese Banging head
06-01-2015, 01:38 PM
I've applied Wellseal to both faces of the HG to help to seal again. Was recommended this by various engine builders, one specifically who has had dealings with a formula atlantic powered ae86 and a Cometic Gasket supplier.
06-01-2015, 06:45 PM (This post was last modified: 06-01-2015 06:45 PM by d3nso.)
Her are two NPR Suppliers:
http://www.ebay.com/itm/85-89-1-6L-Toyot...0526829479
http://www.ebay.com/itm/85-89-TOYOTA-MR2...0480222785
Daily Beater: Civic EG5
Work in progress Car: AE86
06-25-2015, 10:27 PM
AlexKTM have sure that blue top have 1,5 1,5 compression rings and redtop 1,2 1,5?
I think that migth be incorrect and may be 1,2 1,5 to the bluetop and 1,5 1,5 to the black/redtop(late bigport)...
I could be wrong!
06-26-2015, 07:17 PM
(06-25-2015 10:27 PM)Ghetto Wrote:  AlexKTM have sure that blue top have 1,5 1,5 compression rings and redtop 1,2 1,5?
I could be wrong!
This is incorrect... I've just re-ringed a high comp piston, 1.2 ring top, 1.5 ring 2nd 2.8 oil control.
Dan -
06-28-2015, 09:45 PM
(06-01-2015 06:45 PM)d3nso Wrote:  Her are two NPR Suppliers:
Woah thanks a lot! And yes, the piston rings are 1.5 1.5 2.8 for the early, tvis, big port,blue top and 1.2 for the next ones (red top, small port, hicomp, whatever)
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 8,414 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 4,500 04-30-2024 09:46 PM
Last Post: Mylesmck
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 16,305 04-19-2021 10:08 PM
Last Post: Hanzo
  Rear Differential rebuild chenfon 10 15,274 11-20-2020 12:18 AM
  AE86 4A-GE 16v engine harness rebuild FanIsHere 7 15,337 01-17-2020 08:04 PM
Last Post: Project D
