Engine rebuild questions
05-22-2015, 01:23 AM
(05-21-2015 11:29 AM)Alex170984 Wrote: [ -> ]Cometic gasket Yes they can be reused... BUT... The Cometic gaskets outer layers use Viton rubber (gee see that again...) to help seal it. A fresh gasket having not been heat cycled, has to be better......
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-28-2015, 11:14 PM
Anyone knows a NPR supplier? Can't find any through google or eBay
05-29-2015, 10:01 AM
I recommend you ask first at local auto parts store. Euro is weak and you will pay (maybe) a lot more buying from uk or outside Europe.
Grab a phone and ask http://www.rochaecastro.pt/pt/catalogo/m...ne-npr-sm/ |
05-29-2015, 07:12 PM
we dont have such things in spain, just spoilers, rims, decals, etc :/
05-29-2015, 07:17 PM
I thought you were Portuguese
06-01-2015, 01:38 PM
(05-22-2015 01:23 AM)oldeskewltoy Wrote: [ -> ](05-21-2015 11:29 AM)Alex170984 Wrote: [ -> ]Cometic gasket I've applied Wellseal to both faces of the HG to help to seal again. Was recommended this by various engine builders, one specifically who has had dealings with a formula atlantic powered ae86 and a Cometic Gasket supplier. |
06-01-2015, 06:45 PM
(This post was last modified: 06-01-2015 06:45 PM by d3nso.)
Her are two NPR Suppliers:
http://www.ebay.com/itm/85-89-1-6L-Toyot...0526829479 http://www.ebay.com/itm/85-89-TOYOTA-MR2...0480222785 Daily Beater: Civic EG5 Work in progress Car: AE86 |
06-25-2015, 10:27 PM
AlexKTM have sure that blue top have 1,5 1,5 compression rings and redtop 1,2 1,5?
I think that migth be incorrect and may be 1,2 1,5 to the bluetop and 1,5 1,5 to the black/redtop(late bigport)... I could be wrong! |
06-26-2015, 07:17 PM
(06-25-2015 10:27 PM)Ghetto Wrote: [ -> ]AlexKTM have sure that blue top have 1,5 1,5 compression rings and redtop 1,2 1,5? This is incorrect... I've just re-ringed a high comp piston, 1.2 ring top, 1.5 ring 2nd 2.8 oil control. Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-28-2015, 09:45 PM
(06-01-2015 06:45 PM)d3nso Wrote: [ -> ]Her are two NPR Suppliers: Woah thanks a lot! And yes, the piston rings are 1.5 1.5 2.8 for the early, tvis, big port,blue top and 1.2 for the next ones (red top, small port, hicomp, whatever) |
| 20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 9,324 |
| Windscreen stoopid(?) questions.... | Mylesmck | 7 | 5,141 |
04-30-2024 09:46 PM Last Post: Mylesmck |
| Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 17,706 |
| Rear Differential rebuild | chenfon | 10 | 16,220 |
11-20-2020 12:18 AM Last Post: totta Crolla |
| AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 16,111 |
01-17-2020 08:04 PM Last Post: Project D |
