Engine mounting insulators
03-29-2008, 05:42 PM
Has anyone ever had a problem with too much vibration being transmitted from the engine to the bodyshell?
I'm wondering if the rubber insulators on the engine mounts have gone hard. Is that possible? I checked the part numbers (12361-16020 front x2, and 12371-33010 rear), and they don't appear to be heavy duty items. I also noticed that the engine doesn't move very much when revved, compared to other AE86s. (It's a JDM 2 door Levin). |
03-29-2008, 06:23 PM
They usually go soft with age, it's very likely that your can has cusco or other aftermarket mounts, which are stiffer and transfer more vibration from the engine.
03-29-2008, 06:51 PM
In my experience, rubber hardens with age.
I actually removed the rubber insulators and checked the part numbers on them in the Toyota EPC. They're standard items. Just found this... "Rubber ageing results in a loss of flexibility, abrasion resistance and elasticity". http://composite.about.com/library/PR/2001/blcsiro2.htm It seems unlikely that these solid blocks would degrade to such an extent, but wondered if anyone else has had an experienced like this. The car has 175000km on the clock. |
03-29-2008, 10:20 PM
Did you change anything else... suspension bushes for example ??
When I installed TRD suspension bushes I immediately noticed an increase in noise and vibration inside the car. My guess is that poly bushes would be even worse. Cheers... jondee86 |
03-30-2008, 12:13 PM
I don't know which bushes are fitted to the car, (they are rubber, though) but it shouldn't make any difference when the car is stationary.
The vibration is being transmitted from the engine, not the road. It's possible that they are heavy duty items, after all. Does anyone know of any cheaper alternative replacements? In the meantime, I've got some Ford Escort/Cortina rubbers in place. These seem a little too soft, though, and possibly allow a little too much engine movement. It might be worth squishing the rubber a bit more, though. |
Horn mounting... | Mylesmck | 6 | 3,127 |
07-12-2023 10:03 AM Last Post: Mylesmck |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 9,408 |
Exhaust back box mounting | totta Crolla | 3 | 5,163 |
12-01-2010 07:44 PM Last Post: totta Crolla |
Levin rotating grills, mounting? | Juhler | 8 | 11,018 |
08-18-2007 02:59 PM Last Post: Juhler |
mounting rear wing on hatch | Aaron | 3 | 5,567 |
04-18-2007 04:22 AM Last Post: JonnyAE86 |
