Engine died.... :(
04-08-2007, 01:26 PM
Engine died.... :(
yes but your oil cirle isn't corect now. THe oiuld doesn't go in a line but comes in and out at the same spot. Could be if you hear tok tok tok that the pistons didn't got to much grease adn fucked up.
04-08-2007, 01:43 PM
Engine died.... :(
1. Check the dipstick. How is the oil level ??
2. Take the radiator cap off. How is the water level ?? 3. Take the oil filler cap off. Look inside. Does the camshaft turn while the engine is cranking ?? Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
04-08-2007, 03:09 PM
Engine died.... :(
Oil level is okay, water too.
But how should i install the oilcooler? |
04-08-2007, 03:10 PM
| Engine died.... :( | |||
04-08-2007, 04:02 PM
Engine died.... :(
The oil runs out and into the sandwich plate
04-08-2007, 04:06 PM
Engine died.... :(
The red arrows are the stock oil in and out
the green ones is the new oil flow to the cooler and return to the sandwich plate
04-09-2007, 03:42 AM
Engine died.... :(
In theory there is nothing wrong with the pipework you have done.
![]() As previously explained, the factory sandwich plate is a bypass type and there will not (should not) be any flow in the loop back to the sump when the engine is at IDLE speed. At higher revs when the oil pressure builds up, the oil pressure regulator valve will open and allow SOME of the oil to flow thru the cooler, or in your case, directly to the sump. The new sandwich plate intercepts the oil heading for the filter, and directs it thru the new cooler. It then flows back to the sandwich plate, thru the filter, and back into the engine thru the central hollow tube. If you had good oil pressure after you installed the new cooler, then it doesn't seem that your problem is related to the cooler install. You need to look further... to see if there is something else that could have gone wrong. Check your cam belt, tensioner, all pulleys and belts for tightness, look for loose wires, leaks, leftover Easter eggs Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
| toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 11,151 |
| Battery died. Headlights now go up but not down. | Age86 | 4 | 6,778 |
09-15-2008 01:18 PM Last Post: banpei |
| Need engine,any engine | Apolan | 25 | 28,703 |
10-29-2006 06:55 PM Last Post: ZaX |
| Car died on me today, RIP fuelpump? | Ivan141 | 12 | 15,655 |
11-21-2005 11:54 AM Last Post: Ivan141 |
