Door Open Notifer ring thing
07-29-2005, 08:30 PM
I want to rip out that annoying sound out of my car. I could either...
Change the sound. somehow
or.
rip out the ringer or whatever.
Sniper
1986 Toyota Corolla SR5
1989 BMW 535i
1986 Volvo 740 GLE
07-29-2005, 08:49 PM
If you can find it you would be able to take out the ringer.
BTW is the ringer stock in your car?
[Image: AEU86 AE86 - Door Open Notifer ring thing]
07-29-2005, 09:40 PM
I've got mine still connected to the old wireloom, so it's outside my vehicle and TE71Corolla didn't put it back. (thank god!)
I'd recomend to remove it entirely. I think it's situated underneath the driverseat if I look at the drawings of the wires.
07-29-2005, 11:42 PM
Can I change the sound? or just rip the whole thing out?
Sniper
1989 BMW 535i
1986 Volvo 740 GLE
07-30-2005, 03:23 AM
Ah, well in my car, the sound seems to be coming from the glove compartment. It dark out so I didnt do any snooping around. BUt i guess my best option is to rip that crap out. lol
Sniper
1989 BMW 535i
1986 Volvo 740 GLE
07-30-2005, 07:41 AM
I just tore part of a tissue off and made a small thick square, and put it in between what makes the vibration (sound) in the glove compartment. Open the glove compartment, and inside to the right toward the top (close to you) there will be a tiny black box, pull that out, and i believe you have to pull it to your left, then unhook the wires from it. get a flathead screwdriver and open the box up (3 or 4 little hooks at the bottom). and stick the tissue where the vibrtions are created. If you cant find it you can always hook it back up with the top cap thing off, open a door, and watch for it, and listen for it(this is just what i did). you should know where to stick the tissure or napkin to stop it from vibrating. Thumbs up!
07-30-2005, 01:44 PM
Down5Zigen Wrote:I just tore part of a tissue off and made a small thick square, and put it in between what makes the vibration (sound) in the glove compartment. Open the glove compartment, and inside to the right toward the top (close to you) there will be a tiny black box, pull that out, and i believe you have to pull it to your left, then unhook the wires from it. get a flathead screwdriver and open the box up (3 or 4 little hooks at the bottom). and stick the tissue where the vibrtions are created. If you cant find it you can always hook it back up with the top cap thing off, open a door, and watch for it, and listen for it(this is just what i did). you should know where to stick the tissure or napkin to stop it from vibrating. Thumbs up!
I do have the blackbox indeed: it has written "buzzer" on it, so I guess its exactly the same thing. Wink
07-31-2005, 12:02 AM
HAHAHAHAHAHAH (Evil Laugher)
I got that little b***h!!!
i wrote down what it says, just incase someone cares what it says.
ah, finally peace in my car....
Sniper
1989 BMW 535i
1986 Volvo 740 GLE
07-31-2005, 12:49 PM
That wasnt so hard now was it Tongue Good job!
  ring gear bolts DJexor 3 8,307 12-26-2016 10:56 PM
Last Post: totta Crolla
  Checking ring gear diff izanagi 3 7,171 07-09-2014 07:38 AM
Last Post: jondee86
  Ring & pinion ratio. izanagi 27 38,337 07-05-2014 07:35 PM
Last Post: assassin10000
  do you confirm the hub ring for our AE86 is 73.1-60.1 mm? makkuro 4 7,229 05-31-2011 06:35 PM
Last Post: Jan Pedersen
  ring and pinion totta Crolla 8 10,164 11-10-2008 07:24 PM
