Distributor cap heat protection
08-30-2005, 03:31 PM
Yesterday, I find out that my distributor plastic cap has been damaged because of high temperature coming from exhaust. I don’t have any heat protection plates so I’ll have to put something to protect new distributor cap. Any suggestion? thx
Fun is not the straight line! |
08-30-2005, 04:14 PM
If you have a stock exhaust you can try finding the upper heat shield for it. You could also try building a distributor heatshield yourself, or you can order one from http://www.aerodyne.net .
08-30-2005, 10:18 PM
made my own...
I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
09-25-2005, 08:45 PM
An aw11 (early MR2) distributor has a built-in heat shield. Run the aw11 dizzy, cap and wire set. Put a new o-ring on before you install it
![]() Or you can make your own... |
| Cam Cap Bolt Snapped!! | Alex170984 | 1 | 5,802 |
06-08-2018 01:17 PM Last Post: Ivan141 |
| 16v distributor hole plug | harkes | 8 | 13,293 |
10-12-2016 11:13 AM Last Post: harkes |
| Changing distributor when carb 4age | izanagi | 14 | 22,448 |
07-04-2016 03:27 PM Last Post: Uzelac |
| Distributor position and cranking | pack | 13 | 26,276 |
07-01-2013 11:08 PM Last Post: pack |
| 4AGE Heat Shielding Intake Gasket | asyrigos | 11 | 28,938 |
04-01-2013 10:58 AM Last Post: asyrigos |
