Differential ae86 lsd kouki
07-06-2011, 10:10 PM
After a lot of months cause me job im start to repair the diff.... but im stuck to some parts!
First is the gear that it has 2 codes 41331-14010 w/lsd & 41331-22020 ! i need the first?and how can i find the correct diameter of gear? i need a zenki gear! second: what means W/LSD third: how can i find the thickness of washers? i found somewhere a table with marks/thickness but my diff has 3 numbers (pics before 3 posts) Thanks |
07-06-2011, 10:52 PM
It might be easiest to ask for that gear on the forum. Many people that might have a broken LSD could miss it (I suppose I have one too, but those parts are all at my parent's house so cant check).
Washers should have standard thickness.. which ones do you mean exactly? W/LSD probably means With LSD. Someone please correct me if I'm mistaken. FABRICA MI DIEM, PVNC! |
07-07-2011, 02:15 PM
acording to this
http://www.toyodiy.com/parts/p_U_198408_...101.4.html 41361 (washer ,rear differentianl side gear thrust No1) has several thickness ![]() this is the table i said before! http://i4.photobucket.com/albums/y147/as...sdfsm4.gif does anyone knows how can we read it?? hmm...i think Ivan its time to drink a coffee with your parents.... :wink: |
07-10-2011, 10:17 PM
07-29-2011, 09:24 PM
Dunno if your on vacation at the moment, but I went and drank that coffee and got you that gear your looking for.....
11-10-2011, 04:35 PM
i wake up this topic due to the new parts that i bought from weir performance and from Ivan !!!!The max grip kit for this diff includes some metal plates with different thickness , and i don't know witch of them is correct to put inside ! it has 6 very thick , 4 with medium thickness and 4 "fat" . Now i install it with the 6 very thick. The install is : gear,plate,disk,plate,disk,plate from one side and the same to the other!
| Differential specs | MatuOjav | 2 | 1,543 |
12-03-2025 07:06 PM Last Post: MatuOjav |
| Rear Differential rebuild | chenfon | 10 | 15,441 |
11-20-2020 12:18 AM Last Post: totta Crolla |
| Some information for those who are about to restore their differential | krullibull | 0 | 4,717 |
06-06-2015 12:44 AM Last Post: krullibull |
| differential lock % | damusto | 8 | 12,697 |
04-17-2013 10:01 PM Last Post: damusto |
| T283 - AE86 differential / LSD problems | ZaX | 0 | 6,426 |
03-04-2012 08:10 PM Last Post: ZaX |
