Differential ae86 lsd kouki
01-20-2011, 04:29 PM
Good evening!!
Does somebody knows if this differential have different axles thickness? other thickness right and other left? |
01-20-2011, 07:39 PM
Hello,
the kouki axle has a bigger axle diameter than the zenki. There is no difference beween right and left. Hope this helps? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
01-20-2011, 09:18 PM
Differential ae86 lsd kouki | |||
01-21-2011, 01:42 AM
Those pictures look healthy.
TA22 should have the same LSD as a zenki AE86 afaik. If the parts in the picture look equally good on both sides, then you probably have a broken lsd, this will cause a lot of 'slop' on the axle. It is a very common problem on ae86 original LSD's, the metal plate holding the gears that the axleshafts connect to breaks pretty easily. FABRICA MI DIEM, PVNC! |
01-21-2011, 02:17 AM
Yes TA22 does have the same axle spline as zenki AE86.
But I´m sure the TA22 axle is shorter because the axle housing of a TA22 is narrower than a AE86 housing. But it could be compensated, because you need to shorten the TA22 axles, from what I remember 5mm each sind to fit the AE86 LSD.# Don´t know if this answers any of your questions... ![]() 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
01-21-2011, 09:59 AM
so.... im starting to open the diff and then check for the length of the axles...
Lets begin..... wish me good luck ......... ![]() |
01-21-2011, 07:43 PM
so..... the results!!!
diff is in good condition (gears & housing) but he want repair kit ( check photos to confirm ) <a target="_blank" href="http://img443.imageshack.us/i/dsc03592t.jpg/"><img src="http://img443.imageshack.us/img443/9232/dsc03592t.th.jpg" border="0"></a><br> <a target="_blank" href="http://img199.imageshack.us/i/dsc03593b.jpg/"><img src="http://img199.imageshack.us/img199/7631/dsc03593b.th.jpg" border="0"></a><br> now the problems....... 1) the left side gear unfortunately is bigger than the right one ![]() first pics is for the right side gear with axle and other 2 is the left one the gap between the gear and the axle is obviously!! <a target='_blank' href='http://img34.imageshack.us/i/dsc03587s.jpg/'><img src='http://img34.imageshack.us/img34/7027/dsc03587s.th.jpg' border='0'></a> <img src="http://img15.imageshack.us/img15/7360/dsc03588t.th.jpg" border="0"></a><br> <a target="_blank" href="http://img402.imageshack.us/i/dsc03589j.jpg/"><img src="http://img402.imageshack.us/img402/3919/dsc03589j.th.jpg" border="0"></a><br> <a target="_blank" href="http://img545.imageshack.us/i/dsc03590c.jpg/"><img src="http://img545.imageshack.us/img545/3066/dsc03590c.th.jpg" border="0"></a><br> 2) something i notice from the first time but i didn't care about that.... according to the manual "align the marks on the case and case cover" page 6 <a target="_blank" href="http://img40.imageshack.us/i/lsd6.gif/"><img src="http://img40.imageshack.us/img40/7890/lsd6.th.gif" border="0"></a><br> I mark the case before remove it and then i see the factory marks wrong!! <a target="_blank" href="http://img152.imageshack.us/i/dsc03594q.jpg/"><img src="http://img152.imageshack.us/img152/2619/dsc03594q.th.jpg" border="0"></a><br> <a target="_blank" href="http://img510.imageshack.us/i/dsc03595l.jpg/"><img src="http://img510.imageshack.us/img510/2235/dsc03595l.th.jpg" border="0"></a><br> btw... i remove the case cover with all the parts and... from one side i found 3 parts and from the other side two!! is this right? i think no..... <a target="_blank" href="http://img262.imageshack.us/i/imag0337p.jpg/"><img src="http://img262.imageshack.us/img262/2193/imag0337p.th.jpg" border="0"></a><br> <a target="_blank" href="http://img15.imageshack.us/i/dsc03596px.jpg/"><img src="http://img15.imageshack.us/img15/6766/dsc03596px.th.jpg" border="0"></a><br> After a quick search i found this photo and check what includes this diff and i haven't one part!!! <a target="_blank" href="http://img256.imageshack.us/i/ae86oemlsdrebuild3.jpg/"><img src="http://img256.imageshack.us/img256/309/ae86oemlsdrebuild3.th.jpg" border="0"></a><br> this is right or the guy that he sold me forgot to put it inside?? ( he said that its never opened ) |
01-21-2011, 10:02 PM
It appears you are missing a clutch plate, and one of the gears is clearly a kouki model (i assume you tried them on the same axle).
The clutch plates are easily replaced with a rebuild kit (check T3, toyota or Weir performance). The little brass plate in pic 2 is usually not included in rebuild kits but can be bought from toyota (I did once). I might be able to find you a spare gear as I have one or two broken LSD's that I have no real use for, but I'd suggest you look around locally first. FABRICA MI DIEM, PVNC! |
01-21-2011, 11:25 PM
Yes i tried it at the same axle!
i search at local toyota for the start and..... i send a pm at the person that sold me... ( is from here and i hope to respond to my message ![]() |
01-22-2011, 09:40 PM
Edited for dumb.
Rear Differential rebuild | chenfon | 10 | 10,779 |
Some information for those who are about to restore their differential | krullibull | 0 | 3,470 |
06-06-2015 12:44 AM Last Post: krullibull |
differential lock % | damusto | 8 | 10,110 |
04-17-2013 10:01 PM Last Post: damusto |
T283 - AE86 differential / LSD problems | ZaX | 0 | 5,297 |
03-04-2012 08:10 PM Last Post: ZaX |
Differential help | uv7x77 | 4 | 5,239 |
12-05-2010 10:18 PM Last Post: Ivan141 |
