(D2?) Quick Release hub?
05-08-2007, 06:32 PM
Hey boys,
To start with, my friends beautiful USDM S12 was stolen ![]() and yes, I know I need a different steering wheel to ![]() thanks a lot for your help!! 86ers.org AE86 x GXE10 |
05-08-2007, 10:58 PM
Man that sucks!
Hope the car can be found back.... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
05-09-2007, 11:13 AM
Most quick release hubs bolt to a std momo-style hub. So you buy a steering wheel that has a momo-style 6-bolt pattern and the hub you need to bolt it into a corolla. Then the quick release just bolts in between the steeringwheel and hub.
Hope you understand this, A wheel to steer the front of the car A pedal to steer the rear |
05-09-2007, 12:00 PM
NoHachi Wrote:Most quick release hubs bolt to a std momo-style hub. So you buy a steering wheel that has a momo-style 6-bolt pattern and the hub you need to bolt it into a corolla. Then the quick release just bolts in between the steeringwheel and hub. Thanks ![]() ![]() As Sekiguchi said, I should really start using my brain sometimes ![]() 86ers.org AE86 x GXE10 |
05-09-2007, 03:24 PM
Also remember that most "cheap" snap-off hubs are about 7cm thick. That means the wheel will come 7 cm's closer towards you. Not a problem in my case (more of an advantage), but it might be a problem for shorter people that already sit close to the steeringwheel.
4age hitting gas too quick means engine stalls - what is the issue? | Ryo | 20 | 34,460 |
06-27-2018 11:15 PM Last Post: Ryo |
Quaife quick rack | totta Crolla | 19 | 24,150 |
03-03-2018 03:32 PM Last Post: Deuce Cam |
Hub size | kazi | 5 | 11,110 |
DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 20,986 |
Quick question - Brake Pad Dimensions | Lt86 | 2 | 6,162 |
06-07-2015 12:08 AM Last Post: jondee86 |
