Crankshaft oil seal - help!
05-03-2007, 10:12 AM
Please help!
I need dimensions of front crankshaft oil seal. They are giving me 3 different dimensions in the store: 35/49/6 or 32/49/6 or 32.5/46/6.
I have red top, big port, 7 ribs engine.
Fun is not the straight line!
05-03-2007, 10:56 AM
Never mind, I've just ordred it directly from toyota for 9€.
05-03-2007, 01:32 PM
max_ae86 Wrote:Never mind, I've just ordred it directly from toyota for 9€.
Toyota Bacic, 70kn !? I need one of those, mine it's leeking heavy ..
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
05-10-2007, 12:27 PM
I'm planning to replace the seal this weekend, so I need more info about this job.
Work steps and tools required?
Thx.
05-10-2007, 03:00 PM
max_ae86 Wrote:I'm planning to replace the seal this weekend, so I need more info about this job.
Thx.
Manual meybi... Wink
05-14-2007, 10:25 AM
Out with the radiator
Off with the accessory belts
Off with the top timing belt covers
Off with the crank pulley
Off with the lower timing belt cover
Off with the timing belt and timing belt drive pulley
Out with the old seal and clean the surfaces
In with the new seal (with a smear of GP grease on the rubbing face)
Reverse the above to assemble
Make sure you :
Mark the position of the timing belt on the pulleys, so that
you don't mess up the timing.
Put the timing belt around the bottom driving pulley before you
replace the crank pulley Blush
Have the correct tools and some patience, as the crank pulley can be
a bit difficult to get off, and needs to be torqued up properly on assembly.
Cheers... jondee86
  Crankshaft stamping Blaze0010 6 3,593 06-10-2024 10:16 PM
Last Post: Blaze0010
  Oil leaks - Help Bojack 4 7,655 10-19-2018 01:34 PM
Last Post: Dave W
  Exhaust fumes in cabin (Hatch seal problem!) Lt86 16 25,425 11-13-2015 01:20 PM
Last Post: pack
  trans oil, lsd oil change Apolan 9 21,189 10-01-2014 03:57 PM
  Crank seal TheGerman 8 13,293 04-12-2014 09:36 AM
Last Post: Apsogos
