07-31-2006, 10:28 PM
Post: #291
Your new exhaust looks very nice! How much was it if you don't mind me asking Smile
[Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]
07-31-2006, 10:39 PM
Post: #292
Header 250€
Apexi WS Universal Muffler 150€
2 1/4" Pipe and mid muffler 300€ (a lot more than I initially expected because I made a lot of wrong decisions)
07-31-2006, 10:46 PM
Post: #293
Looks good.
The exchaust sits very close to the propshaft and rearaxel.. Doesnt it hit when you turn or with heavy load in the car?
07-31-2006, 10:47 PM
Post: #294
nice exhaust. does de sound like this? http://members.cox.net/teamintegra2/apexiws.mp3
07-31-2006, 11:19 PM
Post: #295
It looks that it's close to the prop shaft and rear axle, but it isn't. The nearest is 5-7cm, and the rear axle doesn't play that much. I've tested the car with 4 people inside, going in a bumpy road and i had no problem whatsoever.
oldskull the sound isn't so deep. It's a little more metallic. I'll try to record it soon!
Best regards
08-01-2006, 02:03 PM
Post: #296
why didn't it work to put it under the diff?
I would like to know. would helped me a lot Smile
nice BTW Thumbs up!
Philip
08-01-2006, 08:39 PM
Post: #297
Because it isn't easy (for me, that i don't have short stroke conversion suspension) to have a compromise between having the pipe far from the ground and far from the rear axle.
I don't say that it isn't doable, but it gets a little expensive if you keep trying different distances...
I'll keep trying to help as much as I can. But to be honest, if I knew what I know now about exhausts... I might have kept the stock exhaust for a looooooong time.
No bang for the BIG buck.
Best regards
08-02-2006, 06:44 PM
Post: #298
Well, my car went to dyno again.
I've tested two different settings:
1st:
- Ignition timing at 10º BTDC (stock)
- Intake cam at stock angle
- Exhaust cam at -4º (retarded)
2nd:
- Ignition timing at 14º BTDC
- Intake cam advanced 5º
- Exhaust cam advanced 4º
Joining both graphs
Engine specs:
~ Camshafts - HKS 272in/264ex
~ KN Airfilter
~ Tsudo 4-1 Header
~ 2 1/4" exhaust pipe with mid muffler, ressonator and Apexi WS universal
~ Everything else stock (pistons, injectors, no fpr, etc)
Right now, I'm disassembling the head to install the 0,5 mm TRD head gasket, to do some porting, change all guide bosses with copper ones, 3 angle valve job, and shave 1mm off.
Then i'll try the same cams, and if the torque doesn't rise, i'll just throw in a 256º in the exhaust.
Best regards
08-03-2006, 02:13 AM
Post: #299
Head removed...
News soon...
08-04-2006, 10:15 AM
Post: #300
ok...thx!
thought u had short stroke...
can't wait 'til I see the dyno after mods Thumbs up!
keep up the great work Hurray!
Philip
  1986 Toyota Corolla Levin 2dr GT-Apex ondafly 18 1,247 01-20-2026 05:08 PM
Last Post: decryphe
  Toyota Corolla AE86 LEVIN ( Poland) sylwekgtir 40 65,464 11-23-2018 10:13 PM
Last Post: sylwekgtir
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 19,932 10-07-2018 09:45 PM
  RaceMinded satin black Toyota Corolla AE86 Levin Coupe RaceMinded 22 36,969 09-02-2010 07:25 PM
Last Post: Apolan
  Shell make over a coat of paint williep12 4 8,520 02-01-2010 03:52 PM
Last Post: Kid Karola
