Coilovers with Konis???
07-11-2005, 03:41 PM
Previous owner of my AE86 just told
me that the car has handmade coilovers in the front.
I asked him if I use short stroke AE92 dampers,
and he said no 'cause:
"Koni made dampers -with oil- for the AE sold as a kit with Eibach short springs"
Can that be true?
And if I really have front coilovers wich dampers can I use?
[Image: AEU86 AE86 - Coilovers with Konis???] http://www.jdmbits.com
07-11-2005, 03:51 PM
Toyota Corolla AE92 Koni Sport (yellow) btw filled with gas, not oil.
Part number 8641-1146Sport
Used on my, kris and so on drift ae86.
07-11-2005, 04:55 PM
Thx ZaX,
but did Koni made the set I mentioned in the past?
Plus, you have also coilovers in the back?
If no, what to use, koni also (not coilovers)?
07-11-2005, 05:10 PM
In the back you could use the normal ae86 Koni shocks, but I think it would be better to find some kind of short stroke alternative for the rear as well when your lowering the car alot (to avoid springs coming loose when unloaded)
07-11-2005, 06:03 PM
Ivan141 Wrote:In the back you could use the normal ae86 Koni shocks, but I think it would be better to find some kind of short stroke alternative for the rear as well when your lowering the car alot (to avoid springs coming loose when unloaded)
Is there a short stroke alternative? I got no money for rear coilovers right now...
P.S.: Nobody telling me if Koni made this
oil kit dampers - Eibach spings, I was told about!
07-11-2005, 07:24 PM
HTS
Broken down 1984 Trueno HB
07-11-2005, 07:28 PM
Aico Wrote:HTS
You meen Tokiko?
With what springs?
They work good with front coilovers?
How much do they cost, cause I have trouble finding them here in Greece.
07-11-2005, 08:14 PM
HTS is import only. They are SS and good for coil-overs.
07-11-2005, 08:50 PM
No man, no!
I asked for a -non coilover- damper kit for the rear,
that works gook with coilovers at the front!
07-11-2005, 11:56 PM
Ooh sorry. Didn't read the entire thread. Anyway the HTS can be sold for the rear only and it's a normal damper. No coil-over.
  Carina drivers! - Coilovers for a TA60/62 nyberrg 2 7,747 06-05-2017 10:03 AM
Last Post: nyberrg
  Fitting driftworks CS2 coilovers bozu 2 5,946 05-30-2017 10:50 AM
Last Post: bozu
  D2 Coilovers any good? heshan 18 31,336 04-04-2017 02:40 AM
Last Post: hachirokkos
  Has anyone tried BC Racing coilovers? AlexKTM 9 14,832 09-05-2016 12:28 PM
  Anyone running DIY Coilovers? Rasteirinho 8 15,882 11-19-2013 10:30 PM
Last Post: totta Crolla
