Coil springs...
02-18-2008, 07:13 PM
Coil springs...
I am busting my head about springs for my Hachi...
I already have Koni Sport shocks front and back... Has anyone here experiance with what springs to buy for a drift-all day car? More drift dan all day car... weitec, KW, H&R.... I am a bit lazy and I don't want to make nuclear phisics out of it... If someone has something smart to say... I am all ears...
SNO-MO-BIRU project started- CHIRO |
02-18-2008, 08:14 PM
Coil springs...
8kg in the front, 6kg in the rear is pretty common. I dont know if it really matters what brand you use. You cant go wrong with TRD.
02-18-2008, 11:28 PM
Coil springs...
If you have coilovers, then just worry about the correct rates, the popular 6/4 or 8/6 rates should do fine for a drifter... 6/4 being nicer on the road.
TRD springs are the only ones available in varying strengts I can think of right now if you need springs for the stock struts. The european stuff is almost always oriented towards slightly more sporty than stock setups.. so mostly about 30% more stiff than stock at the very most. FABRICA MI DIEM, PVNC! |
02-19-2008, 12:29 AM
Coil springs...
yes im also still shopping for springs.. the best i can find (non-coilover-like) is APEX springs - going for 163 eur here in slovenia. Might even be cheaper to get them from the aeu shop. Hey Art, any discount for oldtimers like me?
02-19-2008, 03:38 AM
Coil springs...
2 Apolan- A friend of mine got the dilership for KW... I will ask him tumorow... Although... they don't have specfied AE86 springs, Twingo springs and so on.. they have the diameter, number of circles and thickness of the wire... also stifness...
So, we have to measure our springs front/back and send him a request... I don't have coilovers... So stock dimension coil springs (slightly lower) will do just fine as long as they are stiff SNO-MO-BIRU project started- CHIRO |
02-19-2008, 11:02 AM
Coil springs...
mrgud Wrote:I don't have coilovers... So stock dimension coil springs (slightly lower) will do just fine as long as they are stiff You do the math and calc. and we will make custom sprigns ![]() Kas & Carinho just copied Paradise racing Coilover springs with slight mods... waiting for driving impressions. Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
02-19-2008, 11:37 AM
Coil springs...
mrgud, that would be great.
Front: 4kg/mm - 40mm lowering Rear: 3-4kg/mm - 30mm lowering Are you looking for sth along theese lines as well?
02-21-2008, 11:04 PM
Coil springs...
OK...
here's the deal... My new question... What is the inner radius or diameter of Hachi stock springs, also what is the stock height? front and back KW has springs that are not specified by type of wheicle... model... nothing... SNO-MO-BIRU project started- CHIRO |
02-21-2008, 11:13 PM
Coil springs...
yes, please, somebody who has the stock spring off the car. Masure it for us pls. i need springs asap!
02-23-2008, 11:54 AM
Coil springs...
Just happened to have this lying around
![]() Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
| Coil charge time | totta Crolla | 0 | 902 |
01-23-2026 07:27 AM Last Post: totta Crolla |
| Smallport coil | totta Crolla | 2 | 3,942 |
08-12-2022 11:03 AM Last Post: totta Crolla |
| HKS valve springs | totta Crolla | 3 | 4,841 |
| How to test coil with igniter | DJexor | 2 | 10,782 |
03-22-2018 10:01 AM Last Post: Project D |
| Springs from other vehicles?? | FanIsHere | 16 | 21,322 |
05-17-2016 09:12 AM Last Post: FanIsHere |
![AEU86 AE86 - Coil springs... [Image: AEU86 AE86 - Coil springs...]](http://homepages.ihug.co.nz/~wjd/ae86fs~1.jpg)
