Clutch clunking
05-30-2013, 05:26 PM
Clutch clunking
megabob Wrote:
Homem Bomba Wrote:But the OP has not yet responded to my question... it this happens when the car is moving and in gear (shifting, for example) the problem may not even be related to the clutch at all. In that case, I'd say that the diff backlash needs to be re-tigthtened... its a common problem and ppl think it comes from the clutch, but the clunk is propagated through the propeller shaft and it seems like the problem is clutch related.
Cheers![/youtube]
I'm back Smile , i think you might be right regarding the Diff as its a Cusco 2 way LSD i fitted for Japfest this year but its knackered and defiantly in need of a rebuild.
I've added your vid to my favorites on youtube Cool
Yeah, it may be the case that your CWP backlash was not properly adjusted or maybe the spacer has yielded due to strain... do you recall if the diff was installed with a solid pinion spacer or not?
You may want to subscribe to the channel, as I have recently purchased an LSD for the AE86 and will be performing a rebuild and installation very soon... If you subscribe you will be notified when I put the rebuild video online ;-)
E12 2.0 D-4D - 2002 - "Mariazinha" - [Image: AEU86 AE86 - Clutch clunking]
G6R - 1998 - "Bebedolas" - [Image: AEU86 AE86 - Clutch clunking]
AE86 - 1987 - "Charutinho" - [Image: AEU86 AE86 - Clutch clunking]
Check out my Youtube Channel with lots of AE86 DIY Guides!
05-30-2013, 05:48 PM
Clutch clunking
I might just do that. I'm always looking for vids online regarding AE86 stuff. unfortunately its usually in Japanese Confused
  Clutch Master Cylinder and Clutch Slave Cylinder fitment? christsang7 2 7,365 07-01-2009 07:48 AM
Last Post: jondee86
  Clunking noise coming from the rear axle Rasteirinho 3 6,971 10-11-2008 09:34 AM
Last Post: jondee86
  Problem: Soft clutch pedal - no clutch activation dreja 5 10,138 02-09-2006 11:27 PM
Last Post: Denmark
