Cluster lights not working
06-21-2008, 09:05 PM
Even though im new and all, I had the same problem, the fix is I had the switch replaced and everything works. (Considering there were only two switches left on the east coast of the us, i bought both lol)
07-31-2008, 05:19 AM
EDIT: NVM figured it out.
09-16-2008, 12:06 AM
Apologies to resurrect an old thread, but i've stumbled upon a similar issue that has baffled me somewhat. When turning on my lightswitch the dashboard lights work, the headlights work, the number plate lights work, but the rear lights dont.
It cant be the bulbs since the brake lights still work, so i'm a bit baffled. The 'check light' indicator comes up on the dash, but thats all I have to go by. I've checked all the fuses and they're all fine. Any ideas?
09-16-2008, 09:45 AM
Did you check the relays which Choco indicated as his problem in the end. Dumb question
[Image: AEU86 AE86 - Cluster lights not working]
09-16-2008, 02:12 PM
Saying that, no I havent. Whereabouts are they located in the footwell in relation to the fusebox?
09-16-2008, 04:35 PM
I thought in the enginebay fusebox...
09-17-2008, 01:09 AM
banpei Wrote:I thought in the enginebay fusebox...
He swapped it with one in the engine bay, the tail light is somewhere else.
  Brake lights not working takumi_mt 2 2,029 03-07-2024 03:42 PM
Last Post: takumi_mt
  EUDM gauge cluster banpei 22 11,698 08-15-2023 10:48 PM
  EUDM cluster revelations banpei 1 2,707 06-23-2023 09:11 AM
Last Post: r.ave
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 13,727 12-19-2021 11:58 PM
Last Post: gh0st
  working out compression ratios kazi 2 5,122 07-16-2019 08:22 PM
