Charmant gearboxes fot the Hachi - T-50
10-20-2005, 11:11 AM
The gearbox WILL FIT your AE86
BUT.................. the part ( i have no english name for it) (in Swedish it´s called sprängkåpa) will also fit - but the hydraulic thingy for the clutch in on the opposite side. it will hit the exhaust pipe on the AE86. So you need to change out this part of the gearbox - then it will fit to 100% kris I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
10-20-2005, 11:17 AM
Bellhousing is the word.
AFAIR AE85 has same problem with gearbox clutch slave cilinder. Drifting - best fun you can have in your car with your pants on! |
10-20-2005, 02:33 PM
Where there a lot of charmant's in sweden? I could use a gearbox that's had an easy life...
10-20-2005, 02:41 PM
the easy way to get around that is simle to use some of the metal line that are used for the brakes and run over the manifold along the firewall and to the cylinder
10-20-2005, 03:19 PM
Ivan141 Wrote:Where there a lot of charmant's in sweden? I could use a gearbox that's had an easy life... At the moment there are 12 gearboxes left in Sweden I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
10-20-2005, 10:36 PM
Ivan141 Wrote:Where there a lot of charmant's in sweden? I could use a gearbox that's had an easy life... I know there used to be a wrecker here around Tilburg who used to have dozens of Charmants lying around. But that was a few years ago, dunno if he still got some... "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
10-20-2005, 11:09 PM
Doc, do find out!
Daihatsu Charmant suspension same thru all years? | Allexz | 6 | 9,197 |
12-30-2010 09:27 PM Last Post: banpei |
Daihatsu Charmant, got T50 gearbox? | Hedlund | 8 | 11,690 |
07-20-2010 10:09 PM Last Post: The Doctor |
T50 gearboxes compared | The Doctor | 11 | 18,193 |
03-14-2006 08:34 AM Last Post: Ivan141 |
