Cams for a stock 4age 16v
08-14-2008, 09:13 AM
robokill Wrote:this is my engine running:
81.5 mm pistons
standard head gasket
worked ports and valves (also combustion chamber)
catcams last standard valve cam.
264 252 8.5 and 9mm lift
I am running 134.8 WHP and 150 NM
This is measured on the wheels. So anything is possible.
OMG Huh It's almost 170 horsepower on crankshaft. Great result!
Can I see any videos of your car?
http://ae86.blog.hu - closed
2006 Toyota Corolla Verso 2.2 D4-D
1992 JDM Nissan Silvia PS13 RB26DETT powered
08-15-2008, 01:41 PM
Dyno run:
Hurray! Hurray! Hurray! Hurray! Hurray!
Thumbs up! Thumbs up! Thumbs up! Thumbs up! Thumbs up!
167,11 HP @ 7250 rpm 155 Nm on crankshaft
08-15-2008, 02:56 PM
Grats m8! You have an awesome car! ZDoman tuning FTW! Big Grin
08-15-2008, 07:56 PM
What a fuk!
Very good result mate! And you have the oem ecu!
How do you count the crankshaft horsepower?
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - Cams for a stock 4age 16v]
08-15-2008, 09:55 PM
I think I made a mistake in the calculation for crank. I counted with 25% drive train loss, but as I read on club4ag 20% is a common number.
So my car can do about 160 HP on crank. Thumbs up!
08-17-2008, 01:16 PM
AE86_Z
I have a 4age tvis.
My plans are like yours. I have a 4agze complete bottom end (pistons, rods, crankshaft ect) of ae101 4agze late version. I want to change the low compression pistons with high compression pistons. What do you think? The others parts like pulley, water pump ect can they fit on the engine? Can i use the headgasket of bluetop?
Do you know brands of pistons? Commercial sites in Europe?
Thanks a lot mate!
08-19-2008, 04:09 PM
Video of AE86_Z-s dyno run
http://www.youtube.com/watch?v=hCiQv5ZYKOs
08-27-2008, 01:32 PM
Which the differences between:
1.- http://www.rhdjapan.com/jdm-low/TODA-Rac...AE92-51757
2.- http://www.rhdjapan.com/jdm-low/TODA-Rac...AE92-51847
thanks
08-27-2008, 02:18 PM
eh, one is a set of intake and exhaust cam... the second one is only an intake cam.
otherwise they're pretty much the same stuff. One is a set, the other just a single one intake cam for either the AE86 4AGE or the AE92 4AGE (bluetop/redtop?)
Probably the description seems a bit confusing "for both intake camshafts only". The text is just the same as for the set, they just removed the word exhaust from the description.
hope to have helped.
if you want a technical explanation, i'm not your man Tongue
08-27-2008, 02:48 PM
So, the 1st link includes cams for both exhaust and intake. NOT A set. the prie is for one cam. Simply that cam has the pulley/gear and can use like exhaust (important the gear(?)) and the 2nd link inlude only for intake (not important the gear)
I learn it few minutes ago. Thanks a lot mate.
  Digital speedometer on stock dashboard FanIsHere 0 2,541 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 4,405 11-24-2021 04:26 PM
Last Post: apardal
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 24,738 05-01-2021 10:09 PM
  4AGE 16V engine overheat when at high speed chenfon 32 32,417 12-31-2020 06:39 AM
Last Post: chenfon
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 10,383 11-09-2020 10:51 AM
Last Post: totta Crolla
