Cams for a stock 4age 16v
08-14-2008, 09:13 AM
robokill Wrote:this is my engine running: OMG Can I see any videos of your car? http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
08-15-2008, 01:41 PM
Dyno run:
167,11 HP @ 7250 rpm 155 Nm on crankshaft http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
08-15-2008, 02:56 PM
Grats m8! You have an awesome car! ZDoman tuning FTW!
AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
08-15-2008, 07:56 PM
What a fuk!
Very good result mate! And you have the oem ecu! How do you count the crankshaft horsepower? **COROLLA EE80 - 4AGE 124HP**
08-15-2008, 09:55 PM
I think I made a mistake in the calculation for crank. I counted with 25% drive train loss, but as I read on club4ag 20% is a common number.
So my car can do about 160 HP on crank. http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
08-17-2008, 01:16 PM
AE86_Z
I have a 4age tvis. My plans are like yours. I have a 4agze complete bottom end (pistons, rods, crankshaft ect) of ae101 4agze late version. I want to change the low compression pistons with high compression pistons. What do you think? The others parts like pulley, water pump ect can they fit on the engine? Can i use the headgasket of bluetop? Do you know brands of pistons? Commercial sites in Europe? Thanks a lot mate! **COROLLA EE80 - 4AGE 124HP**
08-19-2008, 04:09 PM
| Cams for a stock 4age 16v | |||
08-27-2008, 01:32 PM
Which the differences between:
1.- http://www.rhdjapan.com/jdm-low/TODA-Rac...AE92-51757 2.- http://www.rhdjapan.com/jdm-low/TODA-Rac...AE92-51847 thanks **COROLLA EE80 - 4AGE 124HP**
08-27-2008, 02:18 PM
eh, one is a set of intake and exhaust cam... the second one is only an intake cam.
otherwise they're pretty much the same stuff. One is a set, the other just a single one intake cam for either the AE86 4AGE or the AE92 4AGE (bluetop/redtop?) Probably the description seems a bit confusing "for both intake camshafts only". The text is just the same as for the set, they just removed the word exhaust from the description. hope to have helped. if you want a technical explanation, i'm not your man
08-27-2008, 02:48 PM
So, the 1st link includes cams for both exhaust and intake. NOT A set. the prie is for one cam. Simply that cam has the pulley/gear and can use like exhaust (important the gear(?)) and the 2nd link inlude only for intake (not important the gear)
I learn it few minutes ago. Thanks a lot mate. **COROLLA EE80 - 4AGE 124HP**
| Digital speedometer on stock dashboard | FanIsHere | 0 | 3,258 |
| 82mm Stock compression Pistons | apardal | 4 | 5,241 |
| Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 26,771 |
05-01-2021 10:09 PM Last Post: Ivan141 |
| 4AGE 16V engine overheat when at high speed | chenfon | 32 | 37,931 |
| 4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 11,886 |
