Camber vs. castor
03-17-2008, 02:41 PM
Camber vs. castor
Why does camber plates reduce castor angle? Is there any reasons to want that? All camber plates I've ever seen moves the top of the struts forward!?!
After installing camber plates my car keeps on turning left or right depending on the last turn. I got close to maximum castor which improved this a bit. Its still not quite as good as before, though. Any thoughts on this?
[Image: AEU86 AE86 - Camber vs. castor]
03-17-2008, 03:21 PM
Camber vs. castor
Hi. It's simple. You done it more negative and after that your tires have much more contact with asphalt.That's the reason why they don't coming back.
KAE70--> http://www.youtube.com/watch?v=VJasjMGVd7k
Ae86 daily drift car rebuild
03-17-2008, 07:37 PM
Camber vs. castor
My Cusco plates also reduced standard caster but you can get more than enough back just by adjusting the caster rod :wink: This will of course change the camber angle as well Banging head
03-17-2008, 10:42 PM
Camber vs. castor
I found the problem: The camber plate bearings don't work as it should Banging head
  What is normal and low caster in Cusco camber plates?? T_AE86 9 19,524 01-07-2016 02:56 AM
Last Post: Deuce Cam
  Camber adjustment vs original struts Lt86 9 13,472 05-07-2015 09:45 PM
Last Post: zenki
  back camber of CBY roiz86 5 12,210 03-24-2013 02:00 PM
Last Post: roiz86
  Camber plates harkes 10 17,815 02-08-2013 03:28 PM
Last Post: pack
  Camber Question? J-86 4 7,078 11-11-2012 10:41 PM
Last Post: J-86
