Cam lift and degree.....?
09-14-2009, 05:15 PM
simple question, what do u gain from higher lift and degree?
09-14-2009, 05:24 PM
Usually horsepower Big Grin I'll let some of our experts translate that into more detail.
09-15-2009, 01:31 AM
Duration -> rpm and power
Lift -> torque
duration and lift -> lots of nm @ low rpm and insane power @ high rpm Smile
Regards
09-15-2009, 04:47 AM
http://www.club4ag.com/faq_and_tech_page..._story.htm
Its not too long a read......
Dan -
09-15-2009, 03:25 PM
Thanks for all the help~~~
And i'm wondering, what kind of input i need to put into small port 16v 4age to match the BT 20v's standard output?
I want to know which one has the most return for the investment....Thanks
09-15-2009, 07:09 PM
lolali Wrote:Thanks for all the help~~~
Ih 160ks pleases you, 20V BT is much easier and cheaper.
If need more, than 16V. Much more options.
09-15-2009, 08:01 PM
Why is that Uzelac? Everyone says that, but who has actually tried to simply throw some 300deg cams into a blacktop, megasquirt it and call it a day?
Would be interesting to see some hard data
09-16-2009, 01:06 AM
NoHachi Wrote:Why is that Uzelac? Everyone says that, but who has actually tried to simply throw some 300deg cams into a blacktop, megasquirt it and call it a day?
Do the same and have the same power from 16v.
And you don't have to change engine (BT aren't really cheap) and install it (ain't cheap if you can't do it alone). Beside, avaliability of parts, new or used, for 16V is much better.
Thats why, IMHO.
Regards
09-16-2009, 08:08 AM
How do you reckon? Just trying to see what your rationale is..
16v will need throttlebodies, pistons, cams, shim-under kit, valvesprings and ECU.
I'm thinking of doing just a 20V and dumping in cams+ECU..grand total is far less then frankensteining a 16v..just don't know what will happen..maybe the australians know more..
09-16-2009, 12:39 PM
NoHachi Wrote:How do you reckon? Just trying to see what your rationale is..
When building something, i allways account for rebuild.
New pistons, ECU (MS) and cams are costs in both options.
It comes if it is more expensive to put ITB and valvesprings on 16v or bu new BT 20V and install it. For me it seems tuning 16v is cheaper.
But, me first would buy 20V BT and be happy with 160PS AE86.
Unfortunately, they are too expensive and highly unavaliable in my region so i went 16V way.
Regards
  Cam Cap Bolt Snapped!! Alex170984 1 5,685 06-08-2018 01:17 PM
  HKS 260 8.0 Cam Card d3nso 5 9,977 02-14-2018 08:29 PM
  Effects of valve lift - worth it going higher? harkes 18 23,616 03-17-2014 09:21 PM
  Max lift on Vitz valve lifters harkes 9 15,382 01-02-2014 10:27 AM
  suspicious TRD cam ;) fax0815 6 12,426 02-02-2013 09:44 PM
