Build your own adjustable fuel pressure regulator ;)
01-20-2012, 07:27 PM
Bean Bandit Wrote:very nice write up Dan Smile
after a quick search I found this how-to and wondered if one would cut the 4A-GE regulator just flush between the flatish surface and vacuum nipple (without cutting too deep to not harm the spring), if this would make the need for the modification redundant - not sure if there is a 1.5-2mm gain to be had from that but maybe worth a shot. Only concern I'd have that way is if the top surface where the B&M is resting on collapses/folds...
The problem is the FPR would be too wide @ the seam. I cut through the edge of the top, and remove it. It is only after the top is removed that its outer diameter matches the inner diameter of the B&M case
Dan -
Messages In This Thread
[] - oldeskewltoy - 01-20-2012, 04:21 AM
[] - Bean - 01-20-2012, 11:52 AM
[] - oldeskewltoy - 01-20-2012 07:27 PM
[] - oldeskewltoy - 01-20-2012, 07:29 PM
[] - Bean - 01-21-2012, 06:11 AM
[] - BOOMEX - 01-21-2012, 09:24 AM
[] - oldeskewltoy - 01-21-2012, 06:49 PM
  7AGE Build apardal 5 4,207 08-02-2024 12:11 PM
Last Post: apardal
  Can you convert your 86 back too the original state? gh0st 7 5,838 04-25-2022 04:25 PM
Last Post: gh0st
  4AGE Fuel Regulator Alex170984 6 12,560 02-24-2016 05:59 PM
Last Post: totta Crolla
  How would/have you rebuild your 4age? joaotcgt 6 11,443 07-21-2015 10:40 AM
  Oil Pressure Query Alex170984 2 6,529 12-11-2014 01:25 AM
Last Post: Alex170984
