Build your own adjustable fuel pressure regulator ;)
01-20-2012, 11:52 AM
very nice write up Dan Smile
after a quick search I found this how-to and wondered if one would cut the 4A-GE regulator just flush between the flatish surface and vacuum nipple (without cutting too deep to not harm the spring), if this would make the need for the modification redundant - not sure if there is a 1.5-2mm gain to be had from that but maybe worth a shot. Only concern I'd have that way is if the top surface where the B&M is resting on collapses/folds...
on another note have you made any measurements (bolt spacing, diameter and depth of the piece that goes into the rail)?
if I remember correctly bolt spacing is 39mm and the protrusion is 10mm deep on a 11m diameter - I'm not sure on these figures at all though.
reason I ask if I'm not completely mistaken the Impreza WRX (GDB; 2010-) uses the above dimensions. Most Nissan, Mazda and other Subaru have the same dimensions for the protrusion but the bolt spacing is only ~32mm. Last but not least Hondas have the same bolt spacing (some are offset!) but no protrusion at all but seal with an O-ring.
PS: stock pressure at idle on the 16V (I assume 20V too) is 38-44psi (2.6-3bar) with vacuum signal disconnected and 30-33psi (2-2.3bar) with vacuum signal.
Messages In This Thread
[] - oldeskewltoy - 01-20-2012, 04:21 AM
[] - Bean - 01-20-2012 11:52 AM
[] - oldeskewltoy - 01-20-2012, 07:27 PM
[] - oldeskewltoy - 01-20-2012, 07:29 PM
[] - Bean - 01-21-2012, 06:11 AM
[] - BOOMEX - 01-21-2012, 09:24 AM
[] - oldeskewltoy - 01-21-2012, 06:49 PM
  7AGE Build apardal 5 3,597 08-02-2024 12:11 PM
Last Post: apardal
  Can you convert your 86 back too the original state? gh0st 7 5,366 04-25-2022 04:25 PM
Last Post: gh0st
  4AGE Fuel Regulator Alex170984 6 12,158 02-24-2016 05:59 PM
Last Post: totta Crolla
  How would/have you rebuild your 4age? joaotcgt 6 10,995 07-21-2015 10:40 AM
  Oil Pressure Query Alex170984 2 6,277 12-11-2014 01:25 AM
Last Post: Alex170984
