Brake master cylinder for FC3S brake conversion
02-01-2011, 04:25 AM
Hey guys,
I'm in the finishing stages of my AE85 project, which has included a BEAMS powerplant, Hilux diff, and upgradded brakes. Everything seems to be coming together nicely, except for the brakes.
The brake set up is as follows:
Front: FC3S 4 pot calipers with Nissan Cefiro discs
Rear - S13 K's disc brakes and calipers
The brake lines have been blead thoroughly, but I still have barely any brake feel. We're still running the stock AE85 brake master cylinder. Could this be the issue? I know there are a few other people that are running FC3S brakes. Did you have to upgrade the brake master cylinder? If so, what did you use?
02-01-2011, 06:11 AM
Quote:...running the stock AE85 brake master cylinder. Could this be the issue?
No, only its condition - good or bad, or trying to bleed a caliper that's got a bleeder on its low point.
02-01-2011, 09:45 AM
for your setup a 1" brake master cylinder will be a great option.
(stock is 13/16" on 86)
Without that you can have some brake issue like the pedal that touching the floor before braking (or at least a realy bad feeling)
02-01-2011, 03:51 PM
Yup, had to upgrade the BMC after swapping the RX7 brakes on my car. But it all depends on your stock item, my Zenki mc was 2bolt, I found a 1" Landcruiser mc that bolted right up.
http://monkeymagic86.wordpress.com
02-02-2011, 12:00 AM
I'm using Mk3 Supra MBC (15/16?), the stock one was useless with fc3s calipers. Luckily I had 4 bolt MBC before, so it went right on. Only issue I had was one of the lines facing the tower directly, had to order custom flex hose for that.
[Image: AEU86 AE86 - Brake master cylinder for F...conversion]
http://www.ae86.hu
02-19-2011, 12:55 PM
Can anyone give me a part nr. or tell me exactly with model, year and engine your master brake cyllinder came from??? I'm doing a FC swap too.
I'm also thinking about dropping the brakeservo, like the TRD N2 car, but it only have 1pot calipers, not 4pot like the FC.
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
02-20-2011, 04:44 PM
Toyota Supra MK3 Master cyl. You can find it on ebay. I bought it from there Smile
AE86 GT - SR20DET BlackTop //// Trackday beater
Citroen C4 Coupe VTR - 1.6HDi //// Streetcar
03-03-2011, 12:06 AM
I used a 2 bolts Nissan Navara (year 1990-1992)
It fits without too much work , just some brake lines to bent a little
phil
Filh
Save the RWD cars
  Bigger brake master cylinder options Koen 10 3,229 01-08-2026 03:12 PM
Last Post: r.ave
  20v Blacktop conversion.... Mylesmck 0 1,939 04-29-2024 05:48 PM
Last Post: Mylesmck
  Kouki to Zenki Levin grill conversion? Mylesmck 6 6,316 02-08-2024 10:30 AM
Last Post: r.ave
  4AGE cylinder head plug removal Ivan141 5 5,580 09-30-2023 09:47 PM
  AFM to Map Conversion ps13michi 3 6,375 01-06-2022 10:34 AM
Last Post: ps13michi
