Bore Size help
03-14-2010, 10:52 PM
Bore Size help
i have a bore size of 3.2086in/81.49844mm will the Arias Pistons for Toyota 4AGE 16V Low Compression 8.5 with a 82mm bore size fit my bore size?
03-16-2010, 02:15 AM
Bore Size help
yaun Wrote:i have a bore size of 3.2086in/81.49844mm will the Arias Pistons for Toyota 4AGE 16V Low Compression 8.5 with a 82mm bore size fit my bore size?
IF you have the engine overbored to 82mm they will fit.
Dan -
  Shim size for AM cams kazi 4 6,179 12-18-2017 05:34 PM
Last Post: oldeskewltoy
Wink Hub size kazi 5 11,020 06-09-2017 10:06 PM
Last Post: kazi
  Camshaft sprocket bolt size? harkes 1 5,352 07-03-2015 12:41 PM
Last Post: Dave W
  Oil plug thread size is M18x1.5 ???? Dino86 5 10,720 06-07-2012 04:54 PM
Last Post: Dino86
  what tires size do i need? slowboy2 10 15,810 05-28-2012 09:26 AM
Last Post: Uzelac
