Bore Size help
03-14-2010, 10:52 PM
Bore Size help
i have a bore size of 3.2086in/81.49844mm will the Arias Pistons for Toyota 4AGE 16V Low Compression 8.5 with a 82mm bore size fit my bore size?
03-16-2010, 02:15 AM
Bore Size help
yaun Wrote:i have a bore size of 3.2086in/81.49844mm will the Arias Pistons for Toyota 4AGE 16V Low Compression 8.5 with a 82mm bore size fit my bore size? IF you have the engine overbored to 82mm they will fit. Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| Shim size for AM cams | kazi | 4 | 8,210 |
| Hub size | kazi | 5 | 13,226 |
| Camshaft sprocket bolt size? | harkes | 1 | 6,562 |
| Oil plug thread size is M18x1.5 ???? | Dino86 | 5 | 12,707 |
| what tires size do i need? | slowboy2 | 10 | 19,519 |
05-28-2012 09:26 AM Last Post: Uzelac |
